Results 1 to 15 of 15
    Default what makes 380hp weighs 200lbs and will fit in 2x2 box 18in deep
    more here
    on the right of the page there is a sidebar with more information on the engine
    The new Powertec V8 project is progressing to plan. All the major design work is finalised and tooling for crankcases and drive system is being produced.
    The 72 V8 can be installed with an all new lightweight transaxle (for rear engine installation) or gearbox (for front engine installation).
    The engine will utilise Suzuki GSXR1300 cylinder heads and barrels, while all other major components will be supplied by Powertec. The crankcases are to be cast in high-grade, heat-treated, aluminium and will be machined in-house by Powertec's sister-company, Amicon Engineering. The crankshaft will be of a flat-plane design and manufactured from billet steel by Doug Kiddie Engineering, who currently produce the cranks for the Powertec 1500 and 1500 Turbo engines.
    The V8 will be available with a capacity of 2.0 litre, 2.6 litre, and 3.0 litres. Several advanced features have been designed into this compact V8. For example, the engine is available with optional twin counter-rotating balance shafts, making it ideal for road use as well as racing. Banks of oil pumps are mounted on the side of the motor, F1-style, to scavenge the integral multi-stage dry sump system.
    Powertec are working very closely with Quaife to produce two optional lightweight drive systems.
    A six-speed transaxle, for rear engine installation will be very compact incorporating a transverse gear cluster, reverse gear system and a torque biased limited slip differential. Because of its compact dimensions and lightweight the alternative six-speed sequential gearbox will be ideal for a wide range of front engine installations.
    Phil Abbott, head of the Powertec V8 project, explained "We have been working flat out on the design, to ensure that the packaging, performance and reliability are maximised. The 72 V-angle is the optimum for a compact motor, while the side-mounted scavenge pumps and dry sump ensure a low crankshaft location and subsequently a very low centre of gravity. The performance of these engines will be awesome because we are utilising superbike cylinder heads with their inherent combustion efficiency.
    Our designer, Steve Prentice, has completed the detail design of the cast crankcases and billet crankshaft. This is where the inherent reliability will come from. With balance shafts to mute vibration and a range of starters, alternators and clutches to suit individual applications, I am confident of performance with reliability. We expect power to be over 350bhp with maximum torque in the region of 240Nm. The first car to have this motor installed will, of course, be the Radical SR3.
    Originally Posted by Mr E
    "Buy Mr E's amazing clutches. More clutchy than a kangeroo on acid".....
    That is some serious hardcore shit.
    That engine will kick so much fuckin ass..
    What are they putting it in?
    i would think their motorcycles
    Lor
    DEAD 93 GT *just got a 94 5sfe 80k miles
    92 Celica ST
    91 Celica AllTrac SOLD
    no, its not going in motorcycles. that company sells its own racecars on that website under cars for sale. they are going to produce quite a number of them for custom built race cars and such. quaife is building a FR and MR gearbox for it.
    383hp @10000rpm
    207lb-ft @6800rpm
    175lb-ft from 4500rpm
    Hmm a miniture v-8 thats incredible! Thats alot of power comming from a little 3.0 litre. Would those numbers be base off a n/a or a turbo motor?
    Religion has many gods. For this tribe, this is their God.
    **New and improved wavy effect!!
    actually its only a 2.6L. they are working on 2.0 and 3.0 variants
    I thought you were going to say an allison 250
    Jeff
    You can trubo the fuck out of a hayabusa tho.. can someone say twin trubo? oh yeah....
    the heads and cylinders are stock N/A hayabusa.
    someone needs to swap that into an alltrac.
    that is bad ass..
    would be sweet to swap that into a celica
    The accent 0wnz j00 awl! ronin will become famous soon enough
    Melbourne AUS
    turbo nitrous busa, zx12r's with TT and nitrous that come in on WOT.. they are awesome.. this thing would be awesome in a celica.. maybe either a RWD or AWD one though.
    temptation is great, indulgence the work of the devil.
    Twould be better in an MR2 f00z.
    holy woah.
    How much would that motor cost? That would be intresting to swap into any car.
