Results 1 to 11 of 11
    Default Headgasket guide???
    Are there any guides available to replace a headgasket, mine is in the early stages of leaking and would like a guide on how to replace the headgasket, what i need etc etc....
    can get all the tools and parts etc...just not sure on the stripping and putting back together part...!!!!!!
    I.E. settings for torque on the head bolts and timing belt setting up etc...??
    Cheers
    Black Is Best colour.!!!
    1992 JDM ST185...Sold
    You're better off pulling the engine and doing it.
    Especially if you've never done anything like it.
    The tensioner and engine mount bracket are a bitch with the engine in.
    And I'd imagine trying to pull the intake manifold to be at least as bad. Not alot of acess to the bolts/nuts back there.
    How many miles are on your engine?
    Hi
    its done 113000kms so about 70000 miles
    im hoping to get some help, but im told it can be done while still in the car, but yes i agree is far easier with engine out..!!!!
    Minneapolis, MN
    I dunno how bad it is with a 3sgte, but I did mine in the car. It was damn easy to do, didn't even need to remove the exhaust/intake manifolds
    1988 CRX DX - Drag Car
    www.mydragcar.com/snafu
    well its certainly not THAT easy.!!!!!
    virtually everything has to be removed to get the head off.... :thumbsdow
    thanks....
    Tampa, FL
    Snafu, you suck I took the manifolds off and everything when I did mine in the car because I was told the extra weight of the manifolds on the head would throw off the torque readings on the wrench when tightening the head bolts.
    But to the starter of this topic-- mine sucked! That was a miserable 3 days. Of course that's just me. I had tons of those pesky Toyota clamps on hoses that were messed up that kept snapping my fingers, as well as stripped out bolts
    its not that hard. No way would I remove the whole engine to do it. I did a power point on a 5s not to long ago. do a search for it.
    Jeff
    Jeff
    He has a 3SGTE.
    Much harder than a 5S while in the car....
  1. Celica wheel interchangeability guide.
    By roman in forum Celica General
    Last Post: 11-10-2008, 01:23 PM
  2. 7th Generation Celica 00-05 Maintenance Guide
    By DrPaine in forum 7th Generation
    Last Post: 08-01-2005, 08:33 AM
  3. 3sgte rebuild guide?
    By locker in forum General Discussion
    Last Post: 07-21-2005, 04:26 AM
  4. Looking for a Good Guide for Removing Gauges/Install
    By Precisionsick in forum Interior/Exterior Aesthetic Modifications
    Last Post: 05-08-2005, 03:47 PM
