    Senior Member Disco Dan is on a distinguished road Disco Dan's Avatar
    May 2005
    Falls Church, VA
    Default interior mirror light (reading light) on coupe/hatchback
    As most of you know, the convertible has no dome light (for obvious reasons) and so the interior light is located on the base of the mirror, just as many newer cars have in addition to the dome light. So, for those of you who might want a 'reading light' for your car, you could consider getting the mirror from a convertible and mounting it to the inside. The only problem would be that you would need to get a windshield from a convertible as well, because there is a metal clip built into the windshield for mounting the mirror. Anyway, I only mention this because I was looking through eBay's auctions and noticed this:
    http://cgi.ebay.com/ebaymotors/ws/eB...tem=7989805842
    Now, as I said, it'd be a bit expensive, because although the mirror would probably be only $20 shipped (assuming you get the one on eBay) you'd need to essentially either a) find a convertible with the windshield intact (which there is at Crazy Ray's in Jessup, MD, if anyone interested lives near there) and get it off of that, or b) pay to have a replacement window installed, but you've got to specify the convertible when you talk to the glass company, and usually they run a minimum of $200 installed, (unless you can convince your insurance company that the windshield was hit by a rock and needs to be replaced, but that's insurance fraud (oh my))
    I dunno, just thought it'd be a neat idea. I've already got the convertible, so if anything, I'd consider adding a dome light somehow, but I'm very hesitant to mount anything to the interior fabric because I really don't want to give water a good excuse to get in.
    Anywho, if anyone decides to go with it, it'd be neat to see!
    D
    The GT-S also has a mirror lamp between the lamp switch and the sunroof controls. I wanted to find one and install it but it's hard to come by GT-S around here since they are all imported from the U.S.
    92 ST182 Euro/JDM Spec
    2nd Gen 3S-GE
    Chicago, IL
    My car already has a reading light at the sunroof control, too bad it doesn't work.
    '90 Celica GT
    '95 Miata
  1. Batt Light comes on every now and then!
    By Keoni in forum Electrical, Audio & Security
    Last Post: 07-08-2005, 08:06 PM
  2. Help with broken popup light
    By robotninja6 in forum Maintenance, Troubleshooting, & Repair
    Last Post: 02-16-2005, 05:41 PM
  3. Do celicas store Check engine light codes?
    By chinaonnitrous1 in forum Maintenance, Troubleshooting, & Repair
    Last Post: 02-04-2005, 07:37 AM
  4. Replies: 0
    Last Post: 12-14-2004, 08:29 PM
