Results 1 to 9 of 9
    Default Information on how turbos work, and how to pick the right one! READ ME!
    GOOD STUFF!!
    click
    for the specs of my 5sfte
    Good stuff WOT.
    Nice.
    94 Celica ST
    1.8l stock 7A-FE, T3/T4
    04 Mazdaspeed Miata
    1.8l, Factory Turbo, Hard Dog DD Roll Bar, Custom TB inlet pipe, boost controller...it's teh faster
    Minneapolis, MN
    WOW, that's how they work?!?!?!?!
    1988 CRX DX - Drag Car
    www.mydragcar.com/snafu
    Tampa, FL
    I found out a T3 60 trim is in the highest efficiency island on my 4AFE. When I get home I'll post the figures I used in the calculations, but I am assuming they are pretty accurate. That should be just about right though since a Super 60 is often used on the 7AFE.
    Tampa, FL
    All of the math and a good portion of the other stuff is taken from the Garrett advanced site posted above. Some of the figures are estimated since I have no freaking idea what they could be. I based my estimates on information from the Garrett site.
    Max Torque - 5800rpm (from my dyno)
    Horsepower Target- 160
    Engine Displacement- 1.6L / 97.632 ci
    Max rpm- 6500 rpm
    Temperature- 75 F
    Barometric Pressure- 30.08 in / 14.77391 psi
    Volumetric Efficiency (VE)- 95% (usually between 90 and 98 on engines with 16V heads, so I just estimated)
    Intake Manifold Temperature- 120 F (again, just estimated. it's usually between 100 F and 130 F on most cars)
    Brake Specific Fuel Consumption (BSFC)- 58% (usually between 50% and 65% or so, so I picked a # in the middle)
    A/F- 12 (good target AF, right?)
    To plot compressor operating point:
    Wa= HP*(A/F)*(BSFC/60)
    Where:
    · Wa = Airflowactual (lb/min)
    · HP = Horsepower Target (flywheel)
    · (A/F)= Air/Fuel Ratio
    · (BSFC)= Brake Specific Fuel Consumption ÷ 60 (to convert from hours to minutes)
    Wa= 160*12*(.55/60)= 17.6 lb/min of air needed for 160hp
    Calculate required manifold pressure required to meet the horsepower, or flow target:
    MAPreq= [Wa*R*(460+Tm)]/[VE*(N/2)*Vd]
    Where:
    · MAPreq = Manifold Absolute Pressure (psia) required to meet the horsepower target
    · Wa = Airflowactual(lb/min)
    · R = Gas Constant = 639.6
    · Tm = Intake Manifold Temperature (degrees F)
    · VE = Volumetric Efficiency
    · N = Engine speed (RPM)
    · Vd = engine displacement (Cubic Inches, convert from liters to CI by multiplying by 61.02, ex. 2.0 liters * 61.02 = 122 CI)
    MAPreq= [17.6*639.6*(460+120)]/[.95*(6500/2)*97.632]= 21.659 psia
    Subtract atmospheric pressure to get gauge pressure (aka boost):
    21.659 psia - 14.774 psi= 6.885 psig
    I then had to account for pressure loss, which I did not know. I just estimated 2 psi To determine the Compressor Discharge Pressure (P2c), 2 psi will be added to the manifold pressure calculated above.
    P2c= MAP+Ploss
    Where:
    · P2c = Compressor Discharge Pressure (psia)
    · MAP = Manifold Absolute Pressure (psia)
    · Ploss = Pressure Loss Between the Compressor and the Manifold (psi)
    P2c= 21.659+2= 23.659 psi
    This is taken directly from Garret:
    Remember our discussion on inlet depression in the Pressure Ratio discussion earlier, we said that a typical value might be 1 psi, so that is what will be used in this calculation. For this example, assume that we are at sea level, so ambient pressure is 14.7 psia.
    We will need to subtract the 1 psi pressure loss from the ambient pressure to determine the Compressor Inlet Pressure (P1).
    P1c= Pamb-Ploss
    Where:
    · P1c = Compressor Inlet Pressure (psia)
    · Pamb = Ambient Air pressure (psia)
    · Ploss = Pressure Loss due to Air Filter/Piping (psi)
    P1c=14.77-1= 13.77 psia
    With this, we can calculate Pressure Ratio (PIc) using the equation PIc=P2c/P1c
    PIc=23.659/13.77= 1.718
    In the end, I got these two numbers which will be needed for plotting on the compressor maps:
    Corrected Air Flow = 17.6 lb/min / 232.8 CFM
    Pressure Ratio= 1.718
    Now, some of the maps (for Mitsubishi turbos especially) use CFM instead of lb/min so I had to do some searching to find out how to convert the figures. I came up with this:
    Mass Air Flow vs. Volume Air Flow conversion:
    Mass Flow(lb/min) = 0.0756 x Volume Flow(cfm) IF the volume flow is measured at standard temperature and pressure (STP). Otherwise the Ideal Gas Law must be used to first convert the measured volume flow to STP.
    Just the math:
    lb/min = .0756xCFM
    CFM= [lb/min]/.0756
    For anyone with a 4AFE, there's all the math and numbers. You can plug in your own numbers and stuff, and I might even make a spreadsheet that will do all this math for us. It'll be a good tool to put on the site.
    Now you just go and plot You just need to find a good site that teaches you how to read compressor maps. I had a few but can't remember them right now. Basically, if you're farther left than the left-most line on the compressor map, you won't produce enough exhaust gas to spool the turbo. If you're too far off the right of the map, the compressor is going to be way too small. Instant boost, but it won't be efficient at all or produce enough power to reach your hp goal. You want to be close to the center of the greatest efficiency island as you can possibly be. That's the best balance between spool and top-end. Again, don't take this as the gospel because I'm not an expert at this by any means. But it is a good start
    Member ROME is on a distinguished road ROME's Avatar
    Melbourne, Australia
    If it can break, I broke it
    I didn't write this, but some of you might find it helpful. It's pretty neat to play with.
    Right-Click > Save As
    94 Celica ST
    04 Mazdaspeed Miata
