Results 1 to 16 of 16
    Default Whats needed for turbo?
    Ive been seriously considering getting a turbo and Ive only done little research, most of it is common knowledge.
    Ive considered these items into my budget and I just wanted to know if I was missing anything.
    Boost Gauge
    Boost Controller
    Turbo haha
    FMIC
    BOV
    Manifold
    Now I would be taking it to a shop close by that does turbo setup's, and Id basically just give him everything stated except for the manifold and FMIC seems he can make/find them dirt cheap.
    Anything else I shoudl keep in mind.
    - On my car I already have a catback exhaust system, stage 2 clutch, suspension and brakes.
    Is my engine to shitty to slap a turbo on? (3sfe with say a C26 turbo)?
    Will my tranny hold?
    How many PSI would I be able to run with this budgeted turbo install?
    Thanks in advance
    bigger injectors and a way of controlling them?
    Oilpan and turbo lines (Or tap into your oilpan), you need some way of controlling your timing (J&S Safeguard, or MSD BTM), You need gauges like a wideband O2 sensor, or a EGT probe, you might want an oil pressure sensor.
    Minneapolis, MN
    Homemadeturbo.com
    Go under Forced Induction
    Read the Faq son
    1988 CRX DX - Drag Car
    www.mydragcar.com/snafu
    So I will be needing
    Turbo - ebay 100$ (C26)
    FMIC - ebay 100$ ("HUGE" Intercooler)
    IC Pipeing
    Downpipe
    BOV - ebay 35$ (HKS knock off)
    Manifold - 150$
    Boost gauge/AF/Oil
    turbo timer - ebay 10$
    ecu from turbo celica?
    and some kind of fuel management system
    you wont need another ecu, your just going to need bigger injectors and a piggyback fuel/timing controller.
    is this fuel timmer the same as a turbo timmer? If you have a pic of one it might jog my memory.
    Whats needed for turbo? a lot more research
    check the 5sfTe stickie presure2 wrote up in the 6th gen section. it gives a lot of good info
    Boosted. Tuned. Ready.
    turbo timer = something that lets the car run after you remove the key until the turbo cools. its not really necesarry
    fuel/ignition controller = something that will let u add or subtract fuel and ignition timing. you will need this with bigger injectors.
    add to the list a 2 bar map sensor.
    Awsome thanks guys, and I checked the 5sfte sticky, and wasnt sure if it would be the same seems i dont have a 5sfe.
    Once again thanks for all the helpful insight.
    Oh and lagos, I have done some research and was basically makeing a checklist for myself, then Once I got everything I was going to research the companys etc.
    did you get a new car or something? What's up with the sig?
    ^some dude was saying I know shit about cars and that I dont have certain things in my car, im a liar ... so i just flattered him with a sig.
    *Probability of me getting flamed for saying this* If you had a 5SFE instead of a 3SFE I would say to turbo the 5S because at least you have the extra .2L on the 3SFE. The amount of money you are going to spend on map sensors, fuel/timing controllers, and piecing together turbo parts you could get a ST185 front clip and throw in a twin cam 2.0L instead of the motor you have now. The 3SGTE has a way bigger aftermarket also. How much did pressure2 spend on his setup? I know that he had the CT26 upgraded to a CT27 which is about minus $850 of what you are about to spend.
    I dont know if you could do the labor yourself, but if you can you will spend about 3K$ on the swap if you get the clip and you can make back some of that money selling parts that you didnt use from the clip.
    1990 GTS Sold
    With the reasearch and "wise" money spending Im saving 1500$ (doing the install myself and a friend who owns a turbo charging shop)
    In total im spending 1500$ Cnd... and yes you are 100% right on the brootle engine part, however, my understanding is that the 3sfe is the JDM replacement for the 5sfe. And I wanted to do the front clip thing prior to my swap/howver at the time money was a major issue.
    I appriciate your input/concern and Ill be sure to check into it. Thank you
    Minneapolis, MN
    Yeah, those JDM replacements are weird. If you get one for the 4afe, you get a 5afe, which stands at a mighty 1.5 liters
    Glad you got everything worked out.
  1. Wiring Diagrams Needed Asap
    By -=DV=- in forum Maintenance, Troubleshooting, & Repair
    Last Post: 03-12-2005, 05:15 AM
  2. wiring diagrams needed asap
    By -=DV=- in forum Electrical, Audio & Security
    Last Post: 03-11-2005, 11:53 PM
  3. ST185 Dash pinout needed
    By irishtwincam in forum Maintenance, Troubleshooting, & Repair
    Last Post: 02-26-2005, 11:35 PM
  4. 5s crank needed
    By flyspyder55 in forum United States
    Last Post: 02-21-2005, 01:59 AM
