Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 67
  1. #26
    Darkside of the Moon
    Another update, found an image of said spherical bearings with measurements.
    Now we just need to know the diameter and length of our stock rear control arms to make sure these fit!
     ...to the topTop
  2. #27
    hi everyone!!!! new member here lookin for struts and bushings for my girl's 90 celica gts. i see that no one has yet to try the spherical bushings yet. sooooo today when she comes home from work im gonna take off the bushing and measure the inside diameter of the control arm and the length of it as well (with a digital caliper). if it seems close i will probably get a set of those bushings and install them in the car. so finally everyone will have an answer.
     ...to the topTop
  3. #28
    Quote Originally Posted by kotu100
    w00t! That would be badass man.. keep us posted!
     ...to the topTop
  4. #29
    Well.. it has been confirmed that those spherical bushings do not fit, they are a tad to small. Looks like buying new rear control arms is still the only option.
    I'm hoping to hear on the actual control arm diameters and measurements so that maybe we could even find some aftermarket spherical bearings that will work.
     ...to the topTop
  5. #30
    Quote Originally Posted by Trance4c
    I'm actually in the process of doing this right now.
     ...to the topTop
  6. #31
    Got the measurement today for you guys. for the inside diameter of the contorl arm on the hub side is 1.470" this is the best i could get after i scraped the rust off and whatnot. what im wondering is if i make a .050 spacer to fit inside the control arm do you guys think i could weld it to the arm then use the spherical bushing?
     ...to the topTop
  7. #32
    Here is all the spec info you could want on the bearings. Sorry about the pics, I'm no photographer or artist, but it'll do. According to my measurements and the pic Clayton posted above, the only major difference in the bearings is the overall length which is not important, and the body length which is workable. Outside diameter is what I concerned about. Where did this drawing come from and why is it not metric? An o.d. of 1.42" is = to 36.068 which does not sound right to me. I would like to get one of those bearings Clayton. I think it will work. anyway, here you go, all measurements are in mm.
     ...to the topTop
  8. #33
    http://www.planetcampbell.us/Spheric...placement.html
    Came from that link.
     ...to the topTop
  9. #34
    The pn# for the bearings, is that for one bearing or all four?
     ...to the topTop
  10. #35
    Was that written in refference to a Supar or an AT?
    An AT
     ...to the topTop
  11. #36
    Any update on finding out if they do work?
     ...to the topTop
  12. #37
     ...to the topTop
  13. #38
    Unfortunately I have confirmed that these bearings/bushings will not work. They lack approx. .75mm-.80mm in diameter. This is also true for the poly bushings for the st185 as shown below.
    What I would like to know is, I saw a member who posted in a similar thread in the last year or two who replaced his with poly bushings and i would like to know what ones he used. I have yet to find any the right size. The pictures the member posted showed them installed and the bushings were purple. I can't find the thread anywhere but if one of you knows what I'm talking about and can find it, we would appreciate it.
    i am going to start looking at modifying the arms to accept the smaller bearings/bushings. I'll keep it updated here.
     ...to the topTop
  14. #39
    Its the same bearing in all four spots, so its the same part number for all four.
    Looks like unfortunately our only bet is the new arms with the bearings already in them from Toyota unless we can find some aftermarket bearing that work.
     ...to the topTop
  15. #40
    Well when I get back from California I'll be trying to source some rod ends that might be compatible. Until I get back though I won't know. I'll let you guys know as soon as I do.
     ...to the topTop
  16. #41
    Are you talking about this:
    http://celicatech.com/forums/showthread.php?t=7528
     ...to the topTop
  17. #42
    Quote Originally Posted by Adrian Avgerinos
    Adrian,
    Great thread, I do remember that one! I see though that you didn't replace the rear control arm bushings either, look only like the trailing arm. What are you planning to do for that in the future if you are? Obviously this is our only missing replacable piece unless you buy the whole control arm.
     ...to the topTop
  18. #43
    Mmm..nope. This guy had replaced his sphereical bearings with poly bushings. They were purple in color. That's when I remember all this crap starting about you can't do that, it'll mess something up, blah blah blah... I just can't seem to find out who it was or where the thread went. I ask because I have yet to find a bushing that will fit in there properly and I wanted to get more info on his.
     ...to the topTop
  19. #44
    I would suggest staying away from the poly bushings though, they will have a lot more give than a spherical bearing.
     ...to the topTop
  20. #45
    Meh, depends on what hardness is used.
     ...to the topTop
  21. #46
    it doesn't matter how hard, they will still have more play than a spherical bearing. Poly isn't bad if you don't mind squeaks, they're usually a step up from factory. Bearings are more expensive, but hardly ever need replacing and totally eliminate flex in the wrong directions.
     ...to the topTop
  22. #47
    Quote Originally Posted by MoralWarfare
    Actually the arguement has been that the poly won't flex enough in the directions that the bearings go(although moving in some directions not orginally intended). When the bearing is moved there is very little if any resistance, whereas the poly is made to resist being moved. Squeaking shouldn't be a problem if properly lubricated. In the end, I feel the pros and cons will balance out. I am also using some discounted machinable urethane stock so this will be a cheap test. I'll keep it posted.
     ...to the topTop
  23. #48
    Exactly.. the poly flexes laterally which we don't want, which the sphercial bearing flexes axially.
     ...to the topTop
  24. #49
    Been talking to Josh at 185 and he said that if I get him the measurements he will find us the bearings. What do you think, middle man cost worth it?
     ...to the topTop
  25. #50
    Doesn't matter to me.. I'm about to try to get the control arms, so if someone can get the right bearings, I would hope they could get them available to us quickly.
    Let me know, I think this is would be good to have this part available to the community.
     ...to the topTop
  1. A list of Celica magazine articles
  2. Various japanese celica sites
    By Rayme in forum General Discussion
    Last Post: 02-04-2005, 02:55 PM
  3. Celica history / chronology
    Last Post: 12-05-2004, 08:30 PM
