Results 1 to 15 of 15
Thread: Engine Specs
    Default Engine Specs
    THIS POST CREDITED TO FALLENHERO 6GC.NET
    I've been pushing for hardcore engine specs on here for a LONG time. So, with that in mind, I am going to borrow from all over the celica communities and post up the info I have gatherd.
    First, I know not about the 5sfe, so if someone has the specs, post em up. Secondly, if any of you guys come accross any problems, let me know and I'll fix it.
    Also, anything that you feel should be added... let me know.
    A-series: 1.5L, 1.6L and 1.8L, belt-driven overhead cam motors used in Corollas, later Celicas, early Tercels, Chevy Novas (NUMMI-built), and Geo Prizms;
    E-series: 1.4L and 1.5L overhead cam, belt-driven engines used in ’88 and up Tercels and Paseos;
    F-series: 3.9L, 4.0L, 4.2L, pushrod straight six engines used in Landcruisers;
    R-series: 2.2L/2.4L, overhead cam, chain-driven engines used in rear wheel drive only Coronas, older Celicas and pickups;
    M-series: 2.2L through 3.0L overhead cam straight six engines used in Cressidas and Supras;
    S-series: 2.0L and 2.2L belt-driven OHC engines used in Camrys, Celicas and MR2s;
    VZ-series: 2.5L, 3.0L and 3.4L V6 engines used in Camrys, pickups, Lexus ES and T100s;
    UZ-series: 4.0L V8 engines used in the Lexus LS400 and SC400.
    ZZ-series: 1.8L I4's found in newer corollas and celicas among others.
    JZ-Series: 3.0L I6 found in supra, Lexus Is300 and SC300
    ......................................7AFE / 4AGE / 1ZZFE / 2ZZGE
    rod length=.....................132.5 / 122 / 146.5 / 137.9982
    crank throw=...................42.75 / 38.5 / N/A / N/A
    stroke=...........................85.5 / 77 / 91.5 / 85.09
    bore................................81.0 / 81 / 79 / 82.0
    rod stroke ratios
    4ag =1.5843
    7a = 1.5496
    2z = 1.6223
    3s=1.6045:1
    b16 = 1.7
    b18c = 1.58
    b18b = 1.54
    1ZZ-FE
    Bore 79mm
    > Stroke 91.5mm
    > Con. Rod 146.65mm
    > Disp. 1794cc
    > Bore-to-bore spacing 87.5mm
    > Bore wall thickness 8.5mm
    > Intake Valve diam 32mm
    > Exhaust Valve diam 27.5mm
    > Valve included angle 33
    > Compression ration 10.0:1
    > Main Journal diam 48mm
    > Pin Journal diam 44mm
    > Journal overlap 4mm
    > Horsepower @ 6400 rpm 130hp
    > Torque @ 4400rpm 125 ft.lbs.
    > Redline 6600rpm
    2ZZ-GE
    > Bore 82mm
    > Stroke 85mm
    > Con. Rod 140.15mm
    > Disp. 1796cc
    > Bore wall thickness 5.5mm
    > Intake Valve diam 34mm
    > Exhaust Valve diam 29mm
    > Valve included angle 43
    > Compression ration 11.5:1
    > Pin Journal diam 45mm
    > Journal overlap .25mm
    > Horsepower @ 7600rpm 180hp
    > Torque @ 6800rpm 130 ft.lbs.
    > Redline 8100rpm
    > rod length 137.9 mm
    > block height 211.75mm
    > comp height 2zzge 1.228
    > Piston pin diameter 20mm
    7afe
    From AT200 94+ Toyota celica ST's and others
    > Bore 81mm
    > Stroke 85.5mm
    > Con. Rod Na
    > Disp. 1762cc (which is close)
    > Bore-to-bore spacing ???
    > Bore wall thickness ???
    > Intake Valve diam ???
    > Exhaust Valve diam ???
    > Valve included angle ???
    > Compression ration 9.5:1
    > Pin Journal diam 48mm
    > Journal overlap ???
    > Horsepower @ 110 @ 5600 RPM
    > Torque @ 115 @ 2800 RPM
    > Redline 6300rpm
    > rod length 7a= 132.5mm
    > block height 7a = 206mm
    > comp height 7a/4a 1.208 30.7mm
    5SFE
    From ST204 94+ Celica GT's and others.
    Type: Inline 4, Cast Iron Block, Aluminum Head
    Cylinder Numbers (From Front): 1-2-3-4
    Firing Order: 1-3-4-2
    Spark Plug Gap: 0.043 inches (1.1 mm)
    Valvetrain DOHC, 16 valves, 4 vales per cylinder
    Valve Angle: 22.3 Degrees
    Idle 650-750 RPM
    Displacement 2.2 Liter (2164 cc)
    Bore 3.42 inches (87.1 mm)
    Stroke 3.58 inches (90.9 mm)
    Compression Ratio 9.5 : 1
    Redline 6300 RPM
    Horsepower 135 @ 5400 RPM
    Torque 145 @ 4400 RPM
    3SGTE (93 all-trac version)
    > Bore 86mm
    > Stroke 3.386in (~86mm)
    > Con. Rod 5.433in (~138mm)
    > Disp. 1998cc
    > Compression ration 8.5:1 (all but 90-93 which were 8.8:1)
    > Main Journal diam
    > Pin Journal diam
    > Journal overlap
    > Horsepower: 190hp@6000rpm (1988-1989)
    200hp@6000rpm (1990-1993)
    260hp@6500rpm (non-US only) (1994-1999)
    > Torque: 200ftlbs@3200rpm (1988-1989)
    200ftlbs@3200RPM (1990-1993)
    > Redline 7300 RPM
    Models with this engine:
    ST205 (Generation 6 Celica GT-Four),
    ST185 (Generation 5 Celica GT-Four/AllTrac)
    ST165 (Generation 4 Celica GT-Four/AllTrac)
    SW20 (1990-98 Turbo MR-2)
    3sgte info
    3SGE
    US version
    Engine: 2.0L four/cyl EFI DOHC
    Bore: 86mm
    Stroke: 86mm
    Compression Ratio: 9.2:1
    Displacement: 2.0L
    Valve Train: 4v/cyl
    Horsepower: 135hp@5400rpm (1986-1989)
    Torque: 125ftlbs@4800rpm
    Models with this engine: 1986-89 GT-S (USA)
    3S-FE
    Bore: 86mm
    Stroke: 86mm
    Compression Ratio: 9.0:1
    Displacement: 2.0L
    Valve Train: 4v/cyl
    Horsepower: 115hp@5200rpm (1986-1989)
    Torque: 124ftlbs@4400rpm
    honda/acura specs
    4age engine specs
    4agze specs
    4age formula atlantic specs
    7age/5age info
    more 7age work
    More 7age
    Toyota twin cam engines.
    96 celica RHD Curren swaps like crazy
    R series was a 2.2 and 2.4
    And it was in the Forerunners too.
    Redline on the 3SGTE is 72 or 7300[revlimiter].
    Also MZ-series.
    DOCH V6 (FE head) 2.5L, 3.0L and 3.3L used in Windom, Camry, Solara, Highlander, Lexus ES300, ES330, RX300 and RX330.
    _Gary
    93 ST185
    91 ST185 (RIP)
    here - tonnes of toyota model specs...
    just scroll down the year and model...
    http://www.globalcar.com/datasheet/T...GTLiftback.htm
    Now playing with;
    On the 3S-GE you should mention that that is the 1st generation engine, later generations go up to 210 HP and have VVI
    92 ST182 Euro/JDM Spec
    2nd Gen 3S-GE
    What about the T series??
    what about the 4s-fe (1.8L)
    Quote Originally Posted by Žusty View Post
    do you mean the 7AFE?
    No he means the engine that came before the 5sfe. I know that there is an existent 3sfe, but I've always wondered myself where the other revisions go. My only guess is that they either never make it out of the engineering stage or if they pass that never make it out of the factory itself for other reasons, so basically that revision is scrapped and they move on to a new change and thus a new revision.
    Cept that in this case the 4S (1800cc) outnumbers the 3S and 5S.
    They were fitted in ST163's and later most JDM Corona's from 86-96.
    There is even a Corona 4S AWD S/W Automatic
    i was gonna say some revisions went to certain countries, and some never got fuel injection, some both
    good example example is a 21r
    damn i only make 115hp......that suckx
    also some Currens had them, and some NZ new celica's
    Well I guess I should throw my hat in the ring.........Did everyone forget about the 1S from the ST160, ST150, and at least the SV1?
    http://en.wikipedia.org/wiki/List_of_Toyota_engines
    just about the most complete list of Toyota engines i've ever found. it does NOT directly give a ton of info (hp, torque) about the engines, the links do.
    Independent AMSOil Dealer
  1. Engine Swap Wiring Secrets REVEALED!
    By Dr Tweak in forum Custom Engineering/Design/Fabrication
    Last Post: 01-12-2014, 11:09 PM
  2. The 3sgte Swap
  3. List of 7th Gens.
  4. The use of Engine Flush next time you change your oil
    By MrWOT in forum Maintenance, Troubleshooting, & Repair
    Last Post: 05-04-2005, 05:26 AM
  5. FAQ's: exhaust smoke by LoKi
