Page 3 of 16 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 51 to 75 of 378
  1. #51
    nevermind,..i ran out of brake fluid...hahaha
  2. #52
    Instrument light rheostat
    Back-up light switch
    Need to re-do front brakes
    No heat
    Need two front tires
    Left side CV Boot/axle
    Worn clutch
    stuck rear defrost button
    4 rear defrost lines broke
    probably more things that i can't think of right now
    1990 Celica ST w/ 4A-FE engine and manual tranny. Chassis AT-180. Magnaflow Cat, Custom built MSD 8.5mm Super Conductor wires, Silverstone S3F Sparkplugs, 1992 GT Coupe Taillights.
    1986 Toyota Supra Liftback w/ 7M-GE and 5-Speed Manual. K&N Drop-in Air Filter, Hella 200mm ECE Headlamp Conversion w/Sylvania Silverstars, Sony X-Plod Head Unit.
  3. #53
    All of these came with the car:
    Passenger Door Sensor (Door light won't turn on)
    1 Exhaust Manifold Bolt Snapped (I thought it was loose when I bought the car, but when I tried to tighten the nut, the bolt came out)
    Gauge Bezel and Washer Fluid Container vibrate when car is cold
    Front tires need to be replaced.
    Paint is oxidized (Looks fine if I do a good wax)
    Clutch is mushy and old.
    Gas Pedal 'sticks' (Throttle body is probably dirty)
    Cup Holder pops open whenever I hit a small bump.
    No Rear Speakers
  4. #54
    Senior Member Disco Dan is on a distinguished road Disco Dan's Avatar
    May 2005
    Falls Church, VA
    My interior problems when I got the car (92 Gt Convertible):
    - Manual windows
    - Manual locks
    - Windows didn't make a good seal and hence leaked
    - Door-open switches were non-functioning
    - Passenger seat didn't recline very far
    - Shift boot was ugly bright red
    - Floor mats were ugly rubber black and bright red
    - Seats smelled of cigarette smoke
    - Speedometer stopped at 120 mph and volt-meter was not present
    - No tweeters
    - Back speakers (4" in convertibles) were blown
    - Rear driver-side window wouldn't go down all the way
    - Arm rest wouldn't latch
    Since then all of those have been fixed. It now has:
    - Power windows
    - Power locks
    - Power mirrors (LHD power folding and heated)
    - All of the windows have been re-aligned to raise, lower and seat properly
    - Door-open switches work on both sides
    - The arm rest latches
    - The seats have been replaced (and will be replaced again soon with the power options)
    - The shift boot is stock
    - The floor mats are stock
    - The GT-S speedometer has been installed (with mileage set to my current correct mileage)
    - System 10 installed (minus rear tweeters which were never present in the convertible, so I guess you could call it system 8)
    What's still wrong with it?
    - System 10 Cd-player is flaky (so I use the tape player with a CD-to-tape adapter, but the sound isn't as clear or controllable)
    - Rear defrost button is missing. Oh wait, 5th gen convertibles didn't have rear-defrosters. Someone explain to me how the 3rd gen convertibles had them, then the 4th and 5th didn't, then the 6th had them again. ::grumble grumble::
    - Steering wheel could be falling apart or it could be just really nasty 'cause I haven't cleaned it and I often drive after doing work on it, so the grease and oils and other crap get all over it.
    - The LED behind the "defrost + feet" button on the Climate control panel is finicky.
    Maybe the convertible seat belt retractor mechanisms are different from the coupe/liftbacks, but I've never had a problem with them.
    As for the door-open buttons, I fixed mine by taking them apart, then spraying them down with brake cleaner, srubbing them really well (especially the contact surfaces) and putting them back together. You'll need a tiny flat-head screwdriver to pry it open and pull the components out.
    The arm rest latch is just a small black plastic piece attached with two screws. You can pocket one at a junk yard and they won't care.
    Aligning the windows is an all-day affair, and is a series of:
    close the door, raise the window, make note of position
    open the door, lower the window, make adjustments
    and it's complicated further by the fact that you can adjust the windows on all axes. The convertible is the worst though, as you have 4 windows to adjust plus a moveable top. FUN!
    Also, the A/C, heat and temperature knobs that are constantly breaking off, are 5 bucks from Toyota. Not too bad, since you'll be forever trying to find them in a junk yard celica, unless you're the first one to have a go at the car.
    Hope any of that is helpful to anyone.
  5. #55
    Ok, now my question would be HOW do you make the adjustments on the window and what must be done to prep?
    (i.e- remove door panel, adjust manually, etc.)
  6. #56
    My problems were already mentioned
    -Wierd Passenger seatbelt retracting noise
    -Drivers side window rattles only when cracked
    -rear seat cigarette burn from previous owner
    Other than that, it's in pretty good shape.
  7. #57
    Quote Originally Posted by Disco Dan
    (i.e- remove door panel, adjust manually, etc.) Any1 got any ideas?
  8. #58
    Trying To Learn Something New Each Day caneman is on a distinguished road caneman's Avatar
    caneman has donated to the forums!
    May 2005
    Middle Tennessee
    The flux capacitor has been broken since I got the car and I'm running low on dilithium crystals ...
    Welcome to the asylum. The inmates are in charge here.
  9. #59
    Ultimo Miembro Fantástico Gigantesco angryyoungnpoor is on a distinguished road
    Jul 2005
    Saint Charles, MO
    jesus christ, guys. You people should take better care of your cars..
    **sarcasm. I guess at least the drivetrain on these cars are still in decent condition.
    Perhaps Toyota needs to work on getting the interior up to par.
    1990 White GTS/W swap ///// 1992 RED GT
  10. #60
    Ok does any1 know how to adjust the windows?
  11. #61
    May 2005
    Falls Church, VA
    ok ok geez. I go my info from the Factory Service Manual. For everyone who already knows this, sorry for the long graphic:
  12. #62
    Feb 2005
    15lb Boost Town!
    Vent switch buttons do nothing but still light up.
    one of the buttons for the vents is missing.
    it wont switch from outside air or recirc, that button seems stuckish.
    failed to smoke a 2004 GTS in an autocross timetrial haha
    Back plastick peices broken from speaker box breaking loose during e-brake slides
    think the back bushings might be going i hear a clunk now and then.
    exaust mount broke (my friend welded it THANKS SHAWN... )
    front engine mount went (but i replaced)
    which then caused my O2 sensor to break its mounts from the modified header(got that welded)
    passenger side outside handle doesent work, plastic thingy broke (gonna shave it anyways)
    plasitc peice behind the driver on the door seal is broken because....
    seat belt does not retract completely...
    causing dented arm rest on driver side (System 10 door pannels here I come)
    steering wheel flakes daily, but retains nice grip!
    raido bezel broken but functional
    cup holder gone, sick of it popping out all the time..
    no cig lighter (by choice NO smoking sigh in replacement)
    no ashtray(by choice, strobe light/blue LED flasher in place)
    Shocks are Shot
    one of my camber kits dont fit, only the front fits, gotta shave them down a tiny bit or something.
    both passenger and driver seat wont move forward when levered they only lean.
    hole in driver side carpet.
    battery light comes on spiraticly stays on a while or flashes or does whatever weird crap it wants, never seeming to effect performance or radio output?? (200 amp alternator next)
    bolt for header heat cover is broken off inside it.
    power steering leaks a bit, not really enough for a drip, just enough to get everything dirty, same with the engine oil, but im running pure synthetic so i consider it pretty well holding still.
    sunroof wont move at all... all jacked up. front speakers suck and make noise, almost faded all to the rear lol
    misc rattle inside dash that i dont ever hear iwth the stereo up so i dont mind
    lots of screw covers for moulding missing around the cab...
    shift leather disentigrated and is replaced now
    no cd holder pop up thing, its missing just has carpet glued in the bottom lol
    passenger door sensor went
    now drivers side is going
    front rotors are warped a little
    chip in the windsheild (fingers crossed)
    lambo door hinges STILL ABSENT!! WTF
    But hey its a nice car...
    and my alltrac is in great shape! woohooo
    peace
  13. #63
    Junior Member diabolical1 is on a distinguished road
    May 2005
    spiritual disharmony
    sunroof do not move, but i hear the motor
    lights dim when i step on the brakes
    dry-rotted interior pieces (damn Florida!), including the steering wheel covering
    carpeting in the trunk is rooted
    brakes! brakes! brakes!
    suspension is dead ...
    fuel level light comes on intermittently
    that's all i can think of for now. i have my work cut out for me, i guess.
  14. #64
    Jun 2005
    Northern Indiana
    Backed into my garage side with my door open. Door does not latch to close. I need to examine better. I may need to post some pics and get advice. It's been a long and stressful day. Rust patched up though...so there's one thing to cross off the not working list.
    --Aaron
  15. #65
    the blown 4AFE sitting in the engine bay, and the 7AFE sitting in the bed of my truck waiting to replace it with a busted oil pan due to crackmonkey shipping handlers
    that, and a dent in every body panel.
  16. #66
    huh, lets see...
    passengers seat slide, i've tried connecting it with pliers...looks like i will have to weld or something similar
    I painted the interior, then was busted for time and also stupid and used gas to remove the shitty paint and put something else on. Now i have cracked interior pieces.
    The drivers side window used to rattle like crazy, i pulled the door panel off and realized that it was a bolt that had pulled through, i used a big ass washer and it has stopped.
    the drivers side light switch
    the seat belt has actually gotten me caught coming home late, damn thing is sooo loud. I now pull it out all the way and hold it there before i open the door.
    some of the climate/other interior lights will turn on/off randomly.
    it looks like i've gone up and down I-5 robbing random clothing stores and fast food restaurants and coffee stands for the past 5 months, the thing looks like a shit hole
    the steering wheel is flaking
    i must not have covered everything when i put in the pioneer deck for there is one speaker that wiggs out on hard accelerations.
    I don't have ac, nothing to worry about there.
    i have replaced the climate contole knob though
    need to have the drivers brain replaced, along with fixing the fender/bumper/hood/headlight
    93 Celica ST - Oldest member of the family, needs TLC.
    92 Corolla AT 5spd - DD
    05 Ninja 250 - MPG getter
    90 Celica Alltrac - Hydrolocked
    Looking for gen III swap.
  17. #67
    lol take the last 8 guys posts and i think i have all that stuff... complete custom laid fiber glass interior here we come... and custom seats... and belts to replace the ones i have (they don't work) lol my multifunctional console is a non functional change collector (nonfunctional because it has a hole in the bottom of it (figure that one out??)
    No joke though, i started to list all the stuff i could think of off the top of my head and it froze up on me... so i'm not going to jinx myself like that
  18. #68
    starting today my seatbelts dont re-tract fully, did i mention the hinge on m ytrunk is broken? whos arent, fuckign gas shocks on coupes driving me insane.
  19. #69
    Quote Originally Posted by wexpav
    i want to shove those up some developers ass...one day i'm opening my trunk and it sounded like it farted, thus my shocks no longer work...
  20. #70
    are there any flip-flop trunk conversions for the 5th gen coupes?
  21. #71
    problems...well lets see
    Driver side door sensor doesn't work
    Seat belts retract slowly and make a weird noise
    power steering rack leaking fluid
    misfiring sometimes...needs new starter
    passenger side view mirror busted
    A/C doesn't blow cold air
    no cup holder (don't really care though)
    needs alignment
    and the best one of all...RUST! mostly around the fenders
  22. #72
    - engine noise vibration
    - sunroof switch (broke by the toyota supvr mech off toyota that my sister went to regarding sunroof leaking and after he mess the switch he claimed that sunroof is not factory installed and sunroof still leak) By the way sunroof is in the owners manual. Should be fired. I fixed leak (except for rear right drain can't be reached) like what toyota parts person by my place told me its just dirt clogging the drain.
    - cracked paint front right fender, scrape on right side mirror, minor scrape on body right side, big scrape rear right bumper corner done by one of those assistant of this toyota supervisor mech in his shop. Someone took it for a ride probably doesn't know how to drive manual or doesn't know how to drive at all. Didn't notice because it was winter time and car is full of salt stain.
    - rattling sound coming from: driver and passenger door, rattling sound on dash sounds like loose screw
    - some rattle on both fenders some broken bar when I checked.
    - passenger headlight shakes
    - broken radio antenna makes those crazy sound I think needs new motor
    - steering wheel cover scrapes, peeling
    - power windows driver side switch have to push hard to put up window
    - sort of busted front speakers
    - Rubber seal passenger door partly comes off top corner.
    - back cover hinge broken
    - passenger door light doesn't turn on (not bulb related)
    - noisy exhaust pipe (big hole)
    - two AC buttons is malfunctioning (high button and defogger with foot)
    - broken visor loose screw
    - moisture inside brake lamp/tail light
    - failed emission high NOx
    - ABS light comes on at times when I start to release clutch from 1st gear. Weird thing is only happens from when engine is first started (from off) never from when I stop at a light and gear to 1st and release clutch.
    - ripped suspension rubber boot/bellow, nneds new suspensions, too
  23. #73
    wow old thread
  24. #74
    wow yea. sounds like some people need to get some shit offa my alltrac before i junk it lol
  25. #75
    I just have to add my bits in here...
    - front tweeters and covers are gone
    - back tweeters are not hooked up and missing the covers
    - cup holder wouldn't stay shut, removed the spring
    - shifter surround is cracked
    - stereo/shifter console is badly scratched
    - door subs were blown and are now fixed with little 6" speakers
    - stereo works only when it wants to
    - steering wheel is shredded
    - drivers seat has a hole where most expected...
    - temp control dial doesnt work
    - drivers seat belt is shredded
    - passenger seat doesn't slide forwards anymore
    - carpet has a hole where the heel of my shoe sits on the gas pedal
    - door sensor for the drivers side is stuck
    - rattling in the dash somewhere
    - exhaust leak
    - power steering leak
    - fuel leak
    - fog light lens is cracked, gonna get new ones and some 6000k bulbs
    - and my ebrake cable is toast!!! gone... rusted away.. :thumbsdow
    Not bad for buying it just 2 weeks ago, slowly I'm going to clean it all up. It's just a bitch to find these parts where I live, there aren't any junk yards with celi's at all! So I'm going to need my parts from some of you and ebay.
  1. A list of Celica magazine articles
  2. Replies: 39
    Last Post: 03-23-2006, 05:46 AM
  3. 92 celica, cd player broken??
    By corvelx in forum Electrical, Audio & Security
    Last Post: 04-17-2005, 06:25 PM
  4. Various japanese celica sites
    By Rayme in forum General Discussion
    Last Post: 02-04-2005, 02:55 PM
  5. Celica history / chronology
    Last Post: 12-05-2004, 08:30 PM
