Page 2 of 16 FirstFirst 1 2 3 4 12 ... LastLast
Results 26 to 50 of 378
  1. #26
    Senior Member RickyNo will become famous soon enough
    Apr 2005
    Quebec, Canada
    Quote Originally Posted by Mike431635
    -There is a HORRIBLE rattle in the rear: need to find out what it is and fix it. I thought it was the struts, but the mounts are secure along with the top of the struts where they attach to the mounts. I will likely be overhauling the rear suspension. New poly bushings everywhere, new swaybar links, perhaps some KONI struts that I can get replaced under warranty when they break.
    Got the same job to do, rear suspension, so i'll do all around.
    You morons have vacancy signs on your asses and my foot's looking for a room!
  2. #27
    Tampa, FL
    Have you figured out exactly what is wrong and needs to be replaced? And where did you pinpoint as the source of the rattle?
  3. #28
    My problems are...
    Broken driver side door open/close sensor
    Passenger seat doesnt retract foward when the recline level is pulled
    Weird seatbelt retracting noise
    The temperature knob is broken....spins like a damn top
    but even with that I'll choose my Toy over any other car around....... I better I'm payin my ass off on it LOL
  4. #29
    Quote Originally Posted by blue_pill85
    My problems are...
    Exactly what is borked inside my car....that seatbelt is annoying VEERRRRRP!...everyones like what in the hell was that. haha
  5. #30
    Quote Originally Posted by Platinum92GTS
    haha
    1993 Celica GT-S - Eibach ProKit, Alltrac Hood, CS Bumper, JDM Clear Corners, Clear Front Bumper, 35% Tints, Kicker RMB8, Lenso Samurai Bronze 17" Wheels
    2007 GTI - NewSouth Boost Gauge, APR Stage 1, Neuspeed P-Flo Intake
  6. #31
    ray_sir_6
    seatbelt retractors
    turbo inproperly installed (in another car)
    6th gear position says "R"
    AWD drivetrain removed
  7. #32
    Ultimo Miembro Fantástico Gigantesco TEAMFaint is on a distinguished road TEAMFaint's Avatar
    Medicine Hat, Ab
    -passenger side door does not open with the key
    -blown struts in the rear
    -hatch cover latches are broken
    -cracked windshield
    -loose driver and passenger side windows
    -bad bushings
    -5sfe instead of 3sgte
    current project; looking =(
  8. #33
    Apr 2005
    Quebec, Canada
    Quote Originally Posted by TEAMFaint
  9. #34
    boosted gt
    passenger seatbelt retractor makes crazy noises
    driver door light switch works sometimes
    broke one of my center vents mounting a portable xm radio
    dash cluster dimmer switch is bad and i have to mess with it sometimes
    uh.... i think thats it
    oh a have a sir mix alot tape jammed in the radio but its a kenwood so i cant blame toyota for that one
  10. #35
    My interior is almost perfect. There is some scratches here and there, but most looks new. Except for the seats, they are good but the leather is a little cracked in some spots, and the radio trim is cracked from taking it out so much. I found a fix for that though. Oh wait, the system 10 corner speaker things suck and and have been broken since i owned the car.
  11. #36
    The passenger seat does not slide forward when the recline lever is pulled. (still broke)
    Seat belts make the funny sounds like all celicas. (still broke -forever)
    Rubber headrest sleeve occasionally pops off bottom metal flange.
    Climate control knob cracked. (fixed -glued)
    Climate control faceplate pealing away from housing. (still broke)
    Hazard buttom paint chipped revealing annoying white light. (fixed -replaced)
    Funny rattle coming from passenger door, stops when pulling in on handle. (still broke)
    Trunk gas lifts worn out. (fixed -replaced)
    Black rubber feet from floor mats snapping off making big mess on floor. (still broke)
    Celica emblems peeled off floor mats. (still broke)
    Shiter boot torn or burnt, hard to tell what happened to it. (still broke)
    2 cigarette burns which probably occured between dealer trade in and final sale. (still burnt)
    Passenger side door sensor does not work. (still broke)
    Crappy aftermarket AIWA deck doesn't push the system 10 speakers worth crap. (looking for factory replacement)
    Tweaters a bit loose. (still loose)
    That's about it. Everything else is fine. The rest of the car is mint outside of both fog light lenses being cracked. I have replacements though as soon as I want to get under there and put em in.
  12. #37
    Gairloch
    -Trip meter is broken, won't go beyond 9 miles.
    -Horn has failed, narrowed it down to the switch in the wheel.
    -Passenger side window won't come down anymore. Either the mechanism is jammed up or the motor is bad.
    -The cubby under the radio in the console is cracked.
    -Speedo only goes up to 120.
  13. #38
    Ultimo Miembro Fantástico Gigantesco PhillyDRFT will become famous soon enough PhillyDRFT will become famous soon enough PhillyDRFT's Avatar
    May 2005
    Philadelphia / Bristol PA
    The mirror pivot switch in the center console, AC and my cig lighter.
    and to everyone with the passenger seat problem, pull the seat out or reach under and try to find a wire hanging down and then reconnect the wire between the rails or rig up a new one for like 2$ at home depot. it baffeled me for months.
  14. #39
    Victoria BC Canada
    I fixed my passenger seat problem (: The cable that latches onto part of the rail, beats me how it connected before, wasn't connected anymore so I welded it on.
  15. #40
    -passenger seat doesnt slide up when you hit the lever
    -heater knob (but recently replaced)
    -rear heated window (only 4 strips work)
    -A/C and heater doesnt work
    -shift boot...barely had one (replaced)
    -no carpet in trunk (dont need it anyway)
    otherwise the interior looks brand new
  16. #41
    This is old
    -heater circuit in the O2 sensor, need a new one (4 wires)
    - and nothing else ...
    _Gary
    93 ST185
    91 ST185 (RIP)
  17. #42
    -OK my A/C don't blow cold air... when I turn the knob it turns to cold but feels like the knob just turns without actually moving anything inside
    -driver's seatbelt retracts slow and makes wierd noise like belt is not grabbing the spool
    -driver's side window does not fully make contact with molding which causes serious leaking problems
    -lol I have no ashtray yet (I'll order 1 wen i get my baby bak)
    -cupholder does not close fully
    -passenger side door will not open or unlock from outside
    I think thats it for now
  18. #43
    Failed Alltrac user InitialD93 is on a distinguished road InitialD93's Avatar
    InitialD93 has been to an annual Dragon Meet! InitialD93 helped get Luni's MR2 back on the road! InitialD93 helped get Play's clutch job done.
    Benton KY
    seatbelt noise
    door light switch
    cup holder
    steering wheel flaking
    hole patched in FMIC pipe
    coolant problem(keeps boiling out randomly)
    oil loss from too large hose on PCV return
    creaks from lowered car and loud exhaust
    2 small cig burns (my fault)
    rear defrost doesnt work
    tail lights/dash lights ghettoed so they work
    hole in rear seat side pannel (had a strut slide into it that was in my back seat)
    AC needs charge and the AC idle up needs some work
    too much camber (wearing inside of tires)
    aftermarket guages need electrical rewiring
    lol im sure i could find more... damn makes it look like i havnt progressed at all when u list it like that
    Dustin, Toyota Tech
    1990 All Trac w/ RC bumper, converted to 93 spec
    2010 Toyota Corolla S
    1979 Malibu (more go fast, less suck)
    2003 BMW Z4 3.0i
  19. #44
    Ultimo Miembro Fantástico Gigantesco GRUMPY514 Vanilla Ice gets more respect.. GRUMPY514's Avatar
    GRUMPY514 helped Azzy get to The Dragon in 2009.
    Jun 2005
    NOVA, Washington DC
    AC Nob
    Sunroof
    Originally Posted by Asinine
    The homoerotic undertone in this thread is so thick you could cut it with a butt plug.
    Originally Posted by Kaiser
    I'd sell my grandmother into slavery for a night with her.......
  20. #45
    Your usual suspects...
    - Passenger seat doesnt retract foward when the recline level is pulled
    - Rattling windows (driver is louder than passy)
    - Horn works intermitently (must be a contact)
    - Passy side plastic retainer clip on seatbelt is missing so metallic lash goes all the way down to the base of the seatbelt.
    - Torn and chipped bumper cover
    - Passy side door switch sometimes jams, not fixing it since I sometimes sit on the door sill while talking to G/F in car and dont want the door lights on.
    - Cracked strut mounts (not torn or rusted)
    92 ST182 Euro/JDM Spec
    2nd Gen 3S-GE
  21. #46
    -Driver's side window rattles
    -Recirculate/Fresh Air button cracked, no light.
    -Fan control knob cracked
    -Passenger side rear window has a minor leak.
    I'd love to see the instructions for fixing the window rattles. Anyone got a link?
  22. #47
    Benton KY
    this thread jinxed me... i hate u all
    Turbo went out this morning for some reason... damn it
    Dustin, Toyota Tech
    2003 BMW Z4 3.0i
  23. #48
    the inside? hmm.... the ac knob, cruise control level, both front windows rattle, so does the drive door panel... cup holder doesnt have the spring anymore, and the a/c doesnt blow cold...and the radio bezel...
  24. #49
    pass side door sensor
    glove compartment light
    reverse lights arent working
    seat belts crank when opening door
    need to replace driver side engine mount (bonnet shakes sometimes)
  25. #50
    Quote Originally Posted by AznKlique
    Just a topic to let other 5th gen owners know what's a common problem with our Celicas' interior, or if theyre problem is just plain weird, and to see if anyone can help out fixing those annoying problems.
    My problems are...
    Rattling driver side window, nasty sound when the bass hits...
    yeah,..i also get that weird seatbelt noise also when i open the door..
    and the brake light keeps popping up for some reason everytime im stepping on the gas hard,...
    any reason why that is?
  1. A list of Celica magazine articles
  2. Replies: 39
    Last Post: 03-23-2006, 05:46 AM
  3. 92 celica, cd player broken??
    By corvelx in forum Electrical, Audio & Security
    Last Post: 04-17-2005, 06:25 PM
  4. Various japanese celica sites
    By Rayme in forum General Discussion
    Last Post: 02-04-2005, 02:55 PM
  5. Celica history / chronology
    Last Post: 12-05-2004, 08:30 PM
