Results 1 to 9 of 9
    Default Fuel problems car wont start
    I'm done converting my engine to a 5sfte however I'm having some problems with the fuel system. it's a st204 from 1994. The car will only run on starting fluid. I'm using the stock ECU and I have a APEXI SAFC I'm going to put in once it's working.
    The stock Distributor was impossible for me to get an rpm signal from with any standalones.
    it starts but I gotta keep giving it gas via the air filter or it just dies. I know its not getting fuel and its not priming while the keys in the on position. can you gives give me some pointers has what to do? I'd appreciate it, it's a 94 Celica 5sfs. I've pulled the spark plugs and they smell like gasoline. The fuel pump only runs while I'm cranking it for some reason. It was backfiring through the intake before I replaced the sparks but that was when I had the distributor in wrong.
    When I tried opening the fuel filter for pressure readings and no fuel shot out .
    I checked all of the efi fuses and they're all great.
    Does anyone have any idea what could be causing this?
    UPDATE: the fuel pump is good I checked again and it starting pumping during cranking.
    Have you verified that you're getting fuel out of the injectors? Maybe the injector resistor pack took a shit?
    '94 GT-Four WRC
    If the pump is on while cranking it should at least start a bit before dying. I'd jumper power to the pump (I can't remember which pins in the diagnostics box but the info should be here somewhere) and be sure it's flowing all the way to the injectors, then go from there.
    I think my ecu might be bad I got it from a junk yard and it thinks the car is cranking at 2000rpm
    despite having a brand new distributor
    Open up the ECU and see if any of the capacitors have leaked.
    Turns out I'm more of a retard than I thought, I bought the federal emissions version rather than the california emissions version
    Question though, do we need to reprogram these ecu's if the car is from the year 94?
    Is it an automatic? I actually think that I have an auto ECU for a 6g laying around, but I think that it's for a 96+
    And yes, it will matter. The 94/95 cars don't run separate cam/crank sensors, while the 96+ do.
    '94 GT-Four WRC
