Results 1 to 19 of 19
Thread: #3 FX corolla
    Default #3 FX corolla
    Hi fellow members. I and my wife are leaving this Saturday on the way from Ohio to Miami Fl. to pick up the third car to my collection of the 3 sets of the 1987 Corolla FX's. Going down interstate highway 75 all the way. Leaving this coming Sat. and planing on being back by the following Friday.
    buffalohunter7321 (Jack)
    Have a safe trip Jack! Is this why you were getting rid of your alltrac?! Needed to make room for another FX???
    '94 GT-Four WRC
    Yes, in away. I still have the all-trac but since the weather is getting warmer and as soon as I get back from Fl. I plan on concentrating on getting it running. People seem to shy away from a NON running car unless you just give it away.
    After getting the trio of Corollas in collector shape, I'll just take the time of going to any car meets and fixing what ever is wrong with any of my collection of carS, and just drive them around the States.
    Oooh... you'll be driving right past me... but I'll probably not be home when you do.
    I never made it down to pick up the car because the Alternator went out about 50 miles from my house.
    Unless the owner can find away to keep the car stored, I'll have to keep on looking fore the third car!
    Too bad about the alternator issue. Hope it got resolved soon.
    Alternator was an easy fix, took it to a good friend I know and he rebuilt it totally. But now have a grounding problem. Some time's I can turn the key to start it and just get nothing. Turn the key off and than back on to start the engine and it works or doesn't . But keep on repeating, turning it on and off and will start finally.
    Try to clean the ground contacts for couple of times.
    I found out that NON of the grounding Leeds from the firewall are connected. I guess that company out in Reno NV. left them undone, when they did the Heads!!? And they are just hanging down in between the firewall and engine. There is about 4 to 5 of them not connected and also found out that they twisted the nuts off all the coil packs, but one. I don't know if that is my problem or not but sometimes my check engine lite comes on and at other times it is off!
    I don't even know where all those flat ground cables go too!!!? Any help would be greatly appreciated.
    Sounds like a messy job. You may need a manual diagram for the wiring.
    What car is this for Jack?
    '94 GT-Four WRC
    My 2000 Dodge Durango 4X4
    Yea. Post up some pictures of the wiring in question and I'll see if I can help at all.
    '94 GT-Four WRC
    What I've found on a dakota forum:
    Drivers side ground from stud on wiper cowl next to brake booster goes to the back on the head.
    4gauge Ground cable from battery to the power steering bracket(connected to the block so basically this is my ground for the block)
    4 gauge Cable from battery to the stud on fedner right behind headlight
    passenger side
    ground from stud on wiper cowl to passenger side valve cover bolt
    should be a ground on the fuel injector wire harness that connects to one of the alternator bolts(at least that's where I have mine)
    Should be some other miscellaneous grounds from wire harnesses to various studs around the engine bay.
    Can you pull on those straps to see where they terminate Jack?
    '94 GT-Four WRC
    Some, but not all, of the flat web copper leads start from the "fire wall" and from the inner finder where the Air breather filter housing is bolted to the inner fender. there are 5 of the web grounds that our not hooked up, one being a double hook up.
    And none go to the head or block?
    Instinctively, I would try to ground them to the nearest engine component.
    '94 GT-Four WRC
    That was my thought's also. Thanks Chris, Jack
