ORIGINALLY POSTED BY: FallenHero on May 13, 2005
I've been pushing for hardcore engine specs on here for a LONG time. So, with that in mind, I am going to borrow from all over the celica communities and post up the info I have gatherd.
First, I know not about the 5sfe, so if someone has the specs, post em up. Secondly, if any of you guys come accross any problems, let me know and I'll fix it.
Also, anything that you feel should be added... let me know.
A-series: 1.5L, 1.6L and 1.8L, belt-driven overhead cam motors used in Corollas, later Celicas, early Tercels, Chevy Novas (NUMMI-built), and Geo Prizms;
E-series: 1.4L and 1.5L overhead cam, belt-driven engines used in 88 and up Tercels and Paseos;
F-series: 3.9L, 4.0L, 4.2L, pushrod straight six engines used in Landcruisers;
R-series: 1.8L/2.4L, overhead cam, chain-driven engines used in rear wheel drive only Coronas, older Celicas and pickups;
M-series: 2.2L through 3.0L overhead cam straight six engines used in Cressidas and Supras;
S-series: 2.0L and 2.2L belt-driven OHC engines used in Camrys, Celicas and MR2s;
VZ-series: 2.5L, 3.0L and 3.4L V6 engines used in Camrys, pickups, Lexus ES and T100s;
UZ-series: 4.0L V8 engines used in the Lexus LS400 and SC400.
ZZ-series: 1.8L I4's found in newer corollas and celicas among others.
JZ-Series: 3.0L I6 found in supra, Lexus Is300 and SC300
......................................7AFE / 4AGE / 1ZZFE / 2ZZGE
rod length=.....................132.5 / 122 / 146.5 / 137.9982
crank throw=...................42.75 / 38.5 / N/A / N/A
stroke=...........................85.5 / 77 / 91.5 / 85.09
bore................................81.0 / 81 / 79 / 82.0
rod stroke ratios
4ag =1.5843
7a = 1.5496
2z = 1.6223
3s=1.6045:1
b16 = 1.7
b18c = 1.58
b18b = 1.54
1ZZ-FE
Bore 79mm
> Stroke 91.5mm
> Con. Rod 146.65mm
> Disp. 1794cc
> Bore-to-bore spacing 87.5mm
> Bore wall thickness 8.5mm
> Intake Valve diam 32mm
> Exhaust Valve diam 27.5mm
> Valve included angle 33
> Compression ration 10.0:1
> Main Journal diam 48mm
> Pin Journal diam 44mm
> Journal overlap 4mm
> Horsepower @ 6400 rpm 130hp
> Torque @ 4400rpm 125 ft.lbs.
> Redline 6600rpm
2ZZ-GE
> Bore 82mm
> Stroke 85mm
> Con. Rod 140.15mm
> Disp. 1796cc
> Bore wall thickness 5.5mm
> Intake Valve diam 34mm
> Exhaust Valve diam 29mm
> Valve included angle 43
> Compression ration 11.5:1
> Pin Journal diam 45mm
> Journal overlap .25mm
> Horsepower @ 7600rpm 180hp
> Torque @ 6800rpm 130 ft.lbs.
> Redline 8100rpm
> rod length 137.9 mm
> block height 211.75mm
> comp height 2zzge 1.228
> Piston pin diameter 20mm
7afe
From AT200 94+ Toyota celica ST's and others
> Bore 81mm
> Stroke 85.5mm
> Con. Rod Na
> Disp. 1762cc (which is close)
> Bore-to-bore spacing ???
> Bore wall thickness ???
> Intake Valve diam ???
> Exhaust Valve diam ???
> Valve included angle ???
> Compression ration 9.5:1
> Pin Journal diam 48mm
> Journal overlap ???
> Horsepower @ 110 @ 5600 RPM
> Torque @ 115 @ 2800 RPM
> Redline 6300rpm
> rod length 7a= 132.5mm
> block height 7a = 206mm
> comp height 7a/4a 1.208 30.7mm
big end bore width. 17mm
5SFE
From ST204 94+ Celica GT's and others.
Type: Inline 4, Cast Iron Block, Aluminum Head
Cylinder Numbers (From Front): 1-2-3-4
Firing Order: 1-3-4-2
Spark Plug Gap: 0.043 inches (1.1 mm)
Valvetrain DOHC, 16 valves, 4 vales per cylinder
Valve Angle: 22.3 Degrees
Idle 650-750 RPM
Displacement 2.2 Liter (2164 cc)
Bore 3.42 inches (87.1 mm)
Stroke 3.58 inches (90.9 mm)
Compression Ratio 9.5 : 1
Redline 6300 RPM
Horsepower 135 @ 5400 RPM
Torque 145 @ 4400 RPM
3SGTE (93 all-trac version)
> Bore 86mm
> Stroke 3.386in (~86mm)
> Con. Rod 5.433in (~138mm)
> Disp. 1998cc
> Compression ration 8.5:1 (all but 90-93 which were 8.8:1)
> Main Journal diam
> Pin Journal diam
> Journal overlap
> Horsepower: 190hp@6000rpm (1988-1989)
200hp@6000rpm (1990-1993)
260hp@6500rpm (non-US only) (1994-1999)
> Torque: 200ftlbs@3200rpm (1988-1989)
200ftlbs@3200RPM (1990-1993)
> Redline 6300 RPM
Models with this engine:
ST205 (Generation 6 Celica GT-Four),
ST185 (Generation 5 Celica GT-Four/AllTrac)
ST165 (Generation 4 Celica GT-Four/AllTrac)
SW20 (1990-98 Turbo MR-2)
3sgte info
3SGE
US version
Engine: 2.0L four/cyl EFI DOHC
Bore: 86mm
Stroke: 86mm
Compression Ratio: 9.2:1
Displacement: 2.0L
Valve Train: 4v/cyl
Horsepower: 135hp@5400rpm (1986-1989)
Torque: 125ftlbs@4800rpm
Models with this engine: 1986-89 GT-S (USA)
Euro 3SGE
Bore: 86mm
Strok: 86mm
Compression Ratio: 9.8:1
Displacement 2.0L
Valve Train:4v/cyl
HorsePower : 128hp@5600RPM
Torque 179NM@44RPM
3S-FE
Bore: 86mm
Stroke: 86mm
Compression Ratio: 9.0:1
Displacement: 2.0L
Valve Train: 4v/cyl
Horsepower: 115hp@5200rpm (1986-1989)
Torque: 124ftlbs@4400rpm
Honda/acura engine specs
4age engine specs
4agze specs
4age formula atlantic specs
7age/5age info
more 7age work
More 7age
Information about other toyota engines
Toyota twin cam engines.
[/quote]
