Results 1 to 1 of 1
    Default N/A Performance Engines and Transmissions Maintenence Thread
    So, 6GC has been up and down for the last couple of days, so I think I'm going to start migrating the stickys over so that all this info isn't completely lost if Coomer ever lets the site go completely to pot. I'll do my best to credit the original authors in case they decide to come over as well.
    ~C.
    Introduction & Basics
    Engines 101 - Get the basics right first.
    Technical Engine Specs- The basics on what all those numbers and letters mean in the engine code.
    Toyota BGB or Service & Repair Manuals. - Where to get the Toyota Service Manuals.
    OBDI CEL Codes - If you've pulled a code check on the list here.
    Resting your A/F ratio (Air fuel ratio) - A quick and easy task to rest your A/F ratio.
    Celica's Fuel Economy - Good or poor gas mileage?
    Feasible and Non-Feasible Swaps- great info on what works, what doesn't & alternatives. (Includes the 2JZ swap)
    Multiple Celica Engines
    Maintenance:
    HOW TO REPLACE YOUR RADIATOR- Great how to article, pictures, tools required.
    Engine Oil & Oil Filter Change.- Covering how to change the oil in your 6Gen Celica.
    Performance:
    Cold Airbox - Info about them and how to make one.
    Custom Exhausts thread. - Sizing , shape & style for NA and Turbo.
    Port & Polish - (External Link) With details on porting & polishing a 3S-GTE head.
    Celica specific Engines.
    7A-FE & 7A-GE, AT200 (see here for 7A-FTE & 7A-GTE)
    Info:
    7A-FE USA specifications.- The 7A-FE specs.
    Maintenance:
    7A-FE Engine Repair Manual. - The AT200 7A-FE repair manual.
    7A-FE Torque Specifications. - Covers all aspects: engine, transmission, brakes, suspension etc.
    Building the 7A-FE. - Great info, also with what not to do.
    Performance:
    Cold Air Intake (CAI) for the ST. - How to make your own CAI for your ST Celica.
    Making a Cold Air Intake (CAI) for the ST. - Another how to, to make your own CAI for your ST Celica.
    Installing a Cat-back Exhaust system. - A great guide on installing the Greddy SP cat-back exhaust system.
    Installing a Header/Extractors on the 7A-FE. - A great how to install a Header/Extractors on the 7A-FE engine.
    5S-FE & 5S-GE, ST204 (see here for 5S-FTE & 5S-GTE)
    Info:
    5S-FE USA & Canadian specifications. - The 5S-FE specs.
    Info about the 5S-GE/GTE engine - Great guide on how to build a hybrid 5S-GE/GTE engine. (pdfile)
    Maintenance:
    5S-FE Engine Repair Manual. - The ST204 5S-FE repair manual.
    5S-FE Torque Specifications. - Covers all aspects: engine, transmission, brakes, suspension etc.
    5S-FE Timing belt and/or Water Pump Replacement. - How to change your timing belt and/or Water Pump on the 5S-FE motor.
    How to Replace Shift solenoids. - How to replace bad shifter solenoids on an automatic Celica GT.
    Engine removal - Removing the 5S-FE.
    Performance:
    Cold Air Intake (CAI) for the GT. - How to make your own CAI for your GT Celica
    SAFC II in a 94 GT. - A great write up on how to install the SAFC II.
    3S-FE, ST202 or ST203
    Info:
    3S-FE Japanese specifications. - The 3S-FE specs.
    Maintenance:
    Performance:
    3rd Gen 3S-GE & 3S-GE BEAMS, ST202
    Info:
    3S-GE Japanese specifications. - The 3S-GE specs.
    3S-GE BEAMS Redtop Information Thread - Information thread about the BEAMS 3S-GE.
    ACIS & BEAMS Discussion thread. - A discussion thread about the 3S-GE engine.
    Maintenance:
    (RM396E) 3S-GE Engine Repair Manual. - The ST202 3rd Gen 3S-GE engine repair manual. (pdfile)
    Performance:
    Guide to modifying the ST202 3S-GE. - A great guide on how to modify the 3rd 3S-GE.
    Swapping:
    3rd Gen 3S-GE swapping. - Info thread on swapping a 3S-GE into a USDM Celica AT200 or ST204
    BEAMS 3S-GE Wiring. - Great info on what rewiring is required for USDM Celica's AT200 & ST204
    3rd Gen 3S-GTE, ST205 & ST205 WRC edition (See here for more info)
    Info:
    3S-GTE Japanese specifications.- The 3S-GTE specs.
    Maintenance:
    (RM398E) 3S-GTE Repair Manual. - The ST205 3rd Gen 3S-GTE engine repair manual. (pdfile)
    (RM399E) ST205 Chassis and Body Repair Manual. - The ST205 GT-Four Chassis & body repair manual. (pdfile)
    Performance:
    (see here for more info)
    Swapping:
    V6, 4A-GE series & other Swaps
    Info:
    Feasible and Non-feasible Swaps. - great info on what works, what doesn't & alternatives. (Includes the 2JZ swap)
    Completed swap thread. - For those who have successfully swapped engines.
    4A-GE info - great info if your thinking of swapping a 4A-GE into your AT200 Celica.
    2GR-FE Discussion thread. - Discussion, info notes regarding swapping a 2GR-FE into a 6Gen Celica.
    Maintenance:
    Performance:
    Transmissions, LSD & Clutch
    Info:
    USDM Transmission Gear Ratios. - The Gear ratios for auto and manual transmissions for the ST GT & GT-S.
    Engine RPM vs Vehicle Speed Graphs. - Great info/graphs showing the vehicle speed (mph & km/h) for various engine speeds.
    E series Transmission. - Great info on the GT4 transmission also has info converting them to 2WD.
    Clutch kit options - Great info for USA members who have swapped a 3S-GTE, BEAMS or a V6 and are running either a S54 or E153 transmission.
    Maintenance:
    AT200 MT transmission fluid change. - Great guide on how to change your manual transmission fluid.
    ST204 AT transmission fluid change. - Great guide on how to change your automatic transmission fluid.
    Clutch Install video. - It's for a different engine, but the same principals apply.
    How To Rebuild Your Clutch Master Cylinder - Great how to guide.
    How To Rebuild Your Clutch Master Cylinder - Another great how to guide, and problem solve etc.
    Removing your transmission (MANUAL) 5sfe. - Great how to, great info if you need to replace your clutch aswell.
    Swapping Transmissions:
    Auto to manual check list. - A checklist of parts you need to swap in a manual transmission.
    Auto to Manual Swap. - A guide on how to swap from an auto to a manual transmission.
    Auto to manual swap. - Converting from an Auto to a Manual on a ST.
    Converting the MR2 transmission for Celica use. - A great how to, on making the transmission work.
    Performance:
    How to articles:
    How to change your Engine Oil & Oil Filter. - Covering how to change the oil in your 6Gen Celica.
    How to check, Check Engine Light (CEL) - On a 94-95 Celica (7A & 5S)
    How to check, Check Engine Light (CEL) - Another how to guide.
    How to replace your radiator - On both M/T & A/T Celicas.
    Engine Bay Renovation. - Very detailed thread about wire tucking, battery relocation, and a few other neat tricks in the engine bay.
    How to Replace a Drivers side Axle - How to replace the drivers side axle.
    How to Refurbish your axles. - Great 'how to' & info thread.
    How to Rebuild Your Clutch Master Cylinder - Great how to guide.
    How to Build Stainless Braided "AN" style lines. - Great how to guide, for any application, Oil lines, Fuel lines, Brake lines etc
    How to remove your engine - Removing the 5S-FE.
    How To:Camry S51 5th gear swap - Great how to guide for installing the taller 5th gear from an S51 into your S54 transmission.
    Part Database
    6GC part database - Covering performance parts.**Currently linked to our basic part list.**
    '98 GS400
