    Default Beam swap what do I need..
    So my 5sfe piston rings are going and I wanna swap a red top beam into it and still use the trans. Do I need to change any mounts or wiring for the ECU or axles? Or should it mostly be plug and play? I know I need to upgrade the fuel pump tho
    Sent from my iPhone using Tapatalk
    Engine, harness, ECU would be all that's needed. You'll need ot do the wiring conversion and all that. Motor mounts should be good, transmission too. May need to do a hybrid clutch setup but not too big of a deal (5sfe clutch disk, 3sge pressure plate).
    Wiregap can do the harness conversion for you.
    You'll need to send him both harnesses, but he's done countless MR2s and Celica hybrid harnesses.
    '98 GS400
    Most used Redtops come with the S54 transmission which is a direct replacement for the trans in your Celica. If the factory clutch needs replacement, you can get a conversion clutch setup from Spec clutches or one of the other major brands.
    http://www.specclutch.com/conversion_combos/view/20
