n00b
Can anyone tell me what I can do to avoid noise from the radio?
I added and AUX connection for my car radio by soldering straight into the audio lines between the CD player and the car radio. I connected my phone to this AUX connection and added an external mic. So the 4 poles (CTIA) connect to LEFT, RIGHT, GROUND, MIC where LEFT, RIGHT and GROUND go to the car radio (connection between the radio and the CD player) and the GROUND and MIC go to an external mic.
The problem is that my phone and the CD player share the same lines so basically the cd player "sends" its audio into my phone through the LEFT and RIGHT lines. Of course, this has no effect on sound and also, I play a silent CD, but, I am having problems with my phone (android) where it automatically turns down the volume all the way to zero. I think this is happening because of a feature that turns down the volume when high audio is detected on the lines. What I thought was maybe there is a way to prevent the cd player from "entering" my phone lines? For example a diode or so..? I know that audio is achieved from change in voltage, but there must also be current I guess..? Also, could you recommend what I can do to avoid noise from the radio? I guess that it is coming from the GROUND line, so maybe some sort of capacitor(here: ) on the ground line?
You have one of the CD players that is separate from the actual radio yes? Since you're handy with a solder gun/iron, switch it's power so that the CD player portion can't send any audio. Or just get an aftermarket head unit and call it a day.
Also, double check your 4 pin wiring to make sure you to don't have your mic ring and ground flipped. From tip to ground should be Left, Right, Mic, Ground. Unless you have a phone that doesn't use the current standard.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Originally Posted by The Captain
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Originally Posted by Murgatroy
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Originally Posted by andy
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
