    Default 1983 celica rear ended.. weird shimmy
    my 83 celica 22r powered manual trans was rear ended we got it puled by body shop and fixed it back up.. but now its scary to drive does a weird shimmy when off the power... looked under car every things solid looking... dont know any thoughts?
    ~-=DEATH BY SNOOCH SNOOCH ! ! !=-~
    : BEWARE OF CRAZY ROMANIANS :
    TRACK STATS AS OF 3-14-10:
    0-60; 6.45sec/ Quarter mile:14.7 @ 126.7mph, uti dyno run: 226bhp 200-/+Whp @ 6300rpm
    From a*almost STOCK JDM 3sGE, with a USDM ECU first gen, COLD AIR,oversized injectors, and a cracked Cherrybomb for that growl (lol!)
    Superstreet cover? -FAIL!!!!
    Did the shop get everything back in spec when they pulled it? Did they give you a print out of where they measured everything as they went to make sure it went back in spec? Were you able to get a 4 wheel alignment done?
    It sounds like to me that something is out of spec and when you come off the power it's cause the chassis to go out of balance. If it was a hard hit and they just eyeballed it's probably way out of spec. I used to work in a body shop and we had a frame rack with a laser measuring system. That worked well and could be the car back into spec or tell you if you couldn't. This really sounds like the unibody is still is out of spec.
    Yeah your right found a 84 celiac supra to swap the remains into though
