Page 3 of 3 FirstFirst 1 2 3
Results 51 to 66 of 66
  1. #51
    Junior Member Il_Barone is on a distinguished road
    Jun 2015
    Genova - Italy
    Here i am
    For now i've driven for about 100 miles.
    Everything looks good, engine's answer is always very quick at low, medium or high regimes.
    The Japspeed exhaust makes a beautiful sound.
    No leaks.
    The only thing i've noticed.... when i drive in the traffic, the cooling fan comes on every 5 minutes. When i stop the engine and i put one hand on the hood, i feel very very very warm coming from the engine bay.
    Is the 3SGTE so hot in your Celicas?
    Have a nice week
    Some pic of my AT
  2. #52
    If you want to bring the temps down, get a heat shield for the turbine housing and wrap the exhaust until it exits the engine bay.
    Also cover the exhaust/engine facing surfaces of the intake/ic with mylar tape where you can.
    Make sure you have a good seal around your radiator that forces air through the core. Use weatherstripping and silicone where required. Good seal > a little lost surface area. Make sure fan shrouding is well sealed to the core in the same manner.
  3. #53
    Would it be hot since you have a tmic and an RC hood??
  4. #54
    Jun 2015
    Genova - Italy
    Quote Originally Posted by MrWOT View Post
    Thank you for your tips
    I noticed that there're two types of heat shield, one adhesive and one non-adhesive sold with ties. Which is better in your opinion?
    Thank you again
  5. #55
    Jun 2015
    Genova - Italy
    Quote Originally Posted by pintoBC_3sgte View Post
    You're right, but i did not imagine that it would be so hot with that hood.
    I'm taking a look around for a slim IC fan....
  6. #56
    It gets hot. An RC hood isn't going to save you from traffic heatsoak.
    https://www.designengineering.com/ca...ials/cool-tape
    That's the kind of thing you want on the engine/exhaust facing intake surfaces, adhesive backed.
    The turbo/exhaust wrap is not adhesive, use steel strapping to hold on. Similar to http://www.designengineering.com/cat...insulation-kit
    Brand isn't specific, that one just came to mind because it's easily accessible to me.
    I use mylar tape from the local hardware store in place of the DEI stuff unless needed (look in the section they keep insulation), the adhesive on the DEI stuff is rated higher.
  7. #57
    Jun 2015
    Genova - Italy
    Ok.
    Sorry for the stupid question, but...what should i have to cover with mylar tape?
    That two areas in the red circles?
    Thank you
  8. #58
    Jun 2015
    Genova - Italy
    I've replaced the original AT hood
    I have also ordered a turbo/exhaust wrap roll. It should arrive in a week.
  9. #59
    Nice! Looks good
  10. #60
    Jun 2015
    Genova - Italy
    Downpipe wrapped
  11. #61
    That looks really good. Nice job.
  12. #62
    Jun 2015
    Genova - Italy
    Thank you
  13. #63
    Jun 2015
    Genova - Italy
    This morning i brought the car to the wheels shop for wheels alignment
    When i turn off the engine and remove the key, the fuel indicator remains active...is it normal on the american celicas or there's something wrong somewhere?
  14. #64
    I was going to say no but I found a picture of the All Trac's dash with the engine off and the fuel gauge was sitting around 3/4 of a tank so I would say you're OK.
  15. #65
    An RC hood with an air-to-air intercooler? Just think of what is going on with that setup. An ST185 does run with a lot of heat under the hood (that’s why the alternator has an air intake duct on it). But the RC hood with an air-to-air intercooler adds to the problem. Consider the air dynamics with that setup.
  16. #66
    Jun 2015
    Genova - Italy
    Quote Originally Posted by 93celicaconv View Post
    For this reason i've changed hood and replaced the original one
