Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 75 of 79
  1. #51
    Junior Member Il_Barone is on a distinguished road
    Jun 2015
    Genova - Italy
    Here i am
    For now i've driven for about 100 miles.
    Everything looks good, engine's answer is always very quick at low, medium or high regimes.
    The Japspeed exhaust makes a beautiful sound.
    No leaks.
    The only thing i've noticed.... when i drive in the traffic, the cooling fan comes on every 5 minutes. When i stop the engine and i put one hand on the hood, i feel very very very warm coming from the engine bay.
    Is the 3SGTE so hot in your Celicas?
    Have a nice week
    Some pic of my AT
  2. #52
    If you want to bring the temps down, get a heat shield for the turbine housing and wrap the exhaust until it exits the engine bay.
    Also cover the exhaust/engine facing surfaces of the intake/ic with mylar tape where you can.
    Make sure you have a good seal around your radiator that forces air through the core. Use weatherstripping and silicone where required. Good seal > a little lost surface area. Make sure fan shrouding is well sealed to the core in the same manner.
  3. #53
    Would it be hot since you have a tmic and an RC hood??
  4. #54
    Jun 2015
    Genova - Italy
    Quote Originally Posted by MrWOT View Post
    Thank you for your tips
    I noticed that there're two types of heat shield, one adhesive and one non-adhesive sold with ties. Which is better in your opinion?
    Thank you again
  5. #55
    Jun 2015
    Genova - Italy
    Quote Originally Posted by pintoBC_3sgte View Post
    You're right, but i did not imagine that it would be so hot with that hood.
    I'm taking a look around for a slim IC fan....
  6. #56
    It gets hot. An RC hood isn't going to save you from traffic heatsoak.
    https://www.designengineering.com/ca...ials/cool-tape
    That's the kind of thing you want on the engine/exhaust facing intake surfaces, adhesive backed.
    The turbo/exhaust wrap is not adhesive, use steel strapping to hold on. Similar to http://www.designengineering.com/cat...insulation-kit
    Brand isn't specific, that one just came to mind because it's easily accessible to me.
    I use mylar tape from the local hardware store in place of the DEI stuff unless needed (look in the section they keep insulation), the adhesive on the DEI stuff is rated higher.
  7. #57
    Jun 2015
    Genova - Italy
    Ok.
    Sorry for the stupid question, but...what should i have to cover with mylar tape?
    That two areas in the red circles?
    Thank you
  8. #58
    Jun 2015
    Genova - Italy
    I've replaced the original AT hood
    I have also ordered a turbo/exhaust wrap roll. It should arrive in a week.
  9. #59
    Nice! Looks good
  10. #60
    Jun 2015
    Genova - Italy
    Downpipe wrapped
  11. #61
    That looks really good. Nice job.
  12. #62
    Jun 2015
    Genova - Italy
    Thank you
  13. #63
    Jun 2015
    Genova - Italy
    This morning i brought the car to the wheels shop for wheels alignment
    When i turn off the engine and remove the key, the fuel indicator remains active...is it normal on the american celicas or there's something wrong somewhere?
  14. #64
    I was going to say no but I found a picture of the All Trac's dash with the engine off and the fuel gauge was sitting around 3/4 of a tank so I would say you're OK.
  15. #65
    An RC hood with an air-to-air intercooler? Just think of what is going on with that setup. An ST185 does run with a lot of heat under the hood (that’s why the alternator has an air intake duct on it). But the RC hood with an air-to-air intercooler adds to the problem. Consider the air dynamics with that setup.
  16. #66
    Jun 2015
    Genova - Italy
    Quote Originally Posted by 93celicaconv View Post
    For this reason i've changed hood and replaced the original one
  17. #67
    When I rebuilt my 3SGTE, the previous owner had removed the heat shield and put an aftermarket downpipe in place of the stock cat converter.
    While everything was apart for the rebuilt, I took the turbo turbine section, exhaust manifold and downpipe for ceramic coating. Put in a aftermarket cat after the downpipe and
    underhood temp was much cooler than a stock setup. Noise is down and New rad helps with cooling. The fan does come on every 5 min or so in hot weather.
    Cheers.
  18. #68
    Jun 2015
    Genova - Italy
    Quote Originally Posted by Cjack View Post
    Cheers.
    Hi
    Thank you for your tip.
    Why did you decide to install an aftermarket cat?
  19. #69
    I install the aftermarket cat for 3 reason. One is to get rid of that smell of no cat. Second is to stop the blue smoke from Idle and third is to lower the noise level. Where I live, there is a bylaw for being too noisy for car muffler. Cops have DB meter that measure SPL.
  20. #70
    Jun 2015
    Genova - Italy
    Here in Italy cops doesn't have the DB meter, but if they suspect your muffler is doing too much noise, they're allowed to send your car at the local test centre (don't know the exact english for this), in addition to a road fine.
  21. #71
    Jun 2015
    Genova - Italy
    On saturday i made the first highway test, i made about 340km (210 miles)
    Average speed of 100/110 km/h (60/70 mph) with a stop of about one hour.
    Everything worked good, good progression of the engine, but i still have a high idle problem.
    Often, not always, the rpms (with engine in temperature) are about 1000/1100. I knew that rpms should be 800/900, right?
    Any ideas or tips on what can i check first?
    Thank you
  22. #72
    We will be working on buddy's 3SGTE right after we finished installing the new filter and fass fuel system on the current truck project. What brand of cat did you go with? He definitely needs a low noise in the quiet neighborhood.
  23. #73
    Jun 2015
    Genova - Italy
    This is my rpms idle.
    They are almost always above 1000 rpm, like the photo.
    Where could i investigate first?
    Thank you
  24. #74
    Check for vacuum leaks
  25. #75
    Adjust the idle air control screw?
