Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 59
    The stock set up is a dual hard line bolting to the turbo from the top. There are a couple of short rubber hoses that connect the hard lines back to the coolant system.
    This page has pictures of the stock coolant lines about half way down.
    http://lovehorsepower.com/joomla/ind...d=16&Itemid=21
    My guess would be that something has happened to the hard lines and the PO either didn't want to buy new ones or couldn't find them.
    92 All Trac-Daily Driver
    Junior Member Il_Barone is on a distinguished road
    Jun 2015
    Genova - Italy
    Quote Originally Posted by Nitro_Alltrac View Post
    PO= previous owner?
    Quote Originally Posted by Il_Barone View Post
    PO= previous owner?
    parole officer... haha, yeah the previous owner would make the most sense.
    Jun 2015
    Genova - Italy
    Ahahahaha
    Could be the parole officer. Hard to tell about the chain of ownership sometimes.
    Jun 2015
    Genova - Italy
    Jun 2015
    Genova - Italy
    Welded by hand plug for the blow-off valve
    Jun 2015
    Genova - Italy
    Yesterday was a passion day
    We dropped in the engine with our faithful friend, the forklift
    We have to connect all the wiring, shift cables, fuel line, drive shafts...but the most of the job was done
    Jun 2015
    Genova - Italy
    It works!
    First, we run the engine without the coil to put the oil (Castrol Magnatec) in circulation, then we connected the coil and it turned on at the first try
    Maybe tomorrow evening we'll do the first ride after a long time, we still mount one driveshaft boot and new tires.
    Here there's a picture of the engine complete and one of another friend of ours (in addition to the forklift)
  10. #35
    nice! always a good feeling when it starts on the first try huuh?
  11. #36
    Quote Originally Posted by celica91gts View Post
    Unlike me..
    Who had to discover the hard way his fuel pump was wired backwards
    Sent from Naboo
  12. #37
    Jun 2015
    Genova - Italy
    Bad news guys.
    Very bad news.
    It leaks coolant from the head gasket. Exactly from the layers of the gasket.
    With the engine on, we can see the coolant dripping from that precise point (in the red circle)
    We torqued the head bolts following the BGB instructions.
    We have not re-torqued them yet. Maybe it's the reason of that leak?
    The head gasket is a Cometic with ARP bolts. Block and head were machine-shaped.
    Did the same thing happen to you? Or do you know if it's a possible problem with Cometic gaskets?
    I'm very demoralized
  13. #38
    Jun 2015
    Genova - Italy
    We re-torque the head bolts and it doesn't leak anymore!!
    We did about 10 km of road test, the engine goes very fast, the Japspeed stainless steel exhaust makes a beautiful sound
    Next week we'll take the car to the bodyshop for a complete repainting
    Pictures coming soon
  14. #39
    glad to hear it man!
  15. #40
    The re-torquing is a wondrous thing...
  16. #41
    Jun 2015
    Genova - Italy
    Quote Originally Posted by 4thgenceli View Post
  17. #42
    Looks great!
  18. #43
    Is the japspeed exhaust made for the st185? I can only find it for the st205.
  19. #44
    Jun 2015
    Genova - Italy
    Quote Originally Posted by jdm_celica_gts View Post
    Yes, it's for st185. I bought the complete exhaust and the downpipe.
    I bought it about one year ago from eBay.
    Seller was "uk-performance-uk", maybe you can ask them if they still have something for the st185.
  20. #45
    Jun 2015
    Genova - Italy
    Hi everybody!
    Car is almost ready!
    I have a CS hood in my garage.... Can i install it or there's a risk of heat problems? My engine has a stock ATA intercooler.
    Thank you
  21. #46
    You will have problems with the tmic and the cs hood. Best bet would be to go fmic with that hood
  22. #47
    Jun 2015
    Genova - Italy
    Quote Originally Posted by pintoBC_3sgte View Post
    For now i don't have enought money for a FMIC.
    Do you think it could be a good solution putting a fan on the TMIC?
    Will be there enough space?
    Thank you
  23. #48
    If you like, I always recommend the NGK Iridium plugs. You will want the BKR6EIX for stock heat range or BKR7EIX for one step colder.
    If you are using Gen3 cams, while it is true the ecu won't do anything for you in relation to them, you can adjust the exhaust cam 6 degrees and make some added power. Perhaps Luni will chime in to confirm that it is correct to retard it by 6deg.
    Getting a bit of additional power, I would recommend a boost controller. Preferably an electronic type. I have always been partial to my Apex-i AVCR. Others like the older Greddy Profec-B. I prefer the AVCR because it has a digital readout and you can see easily what you are doing with no guess work.
    Late to the party.
    Gen3 exhaust cam and Gen2 exhaust cam are same thing except Gen3 is already retarded ~4.5 degrees. So, if youre running Gen3 cams, straight up, youre -4.5 degrees exhaust and +2 intake from where Gen2 cams are.
  24. #49
    Jun 2015
    Genova - Italy
    Quote Originally Posted by Luni View Post
    Late to the party.
    Thank you
  25. #50
    Jun 2015
    Genova - Italy
    Almost ready...
