Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 66
    Junior Member Il_Barone is on a distinguished road
    Jun 2015
    Genova - Italy
    Default Gen2 3SGTE Rebuilding
    Here i am again
    I've been away for a long time because my engine (1991 gen2 3sgte) cracked near the water pump and i had to save money for the repair work.
    I found an used gen2 block in good conditions, and i bought all the necessary for the resuscitation of my All Trac.
    My setup is:
    Gen2 head with Gen3 camshafts
    Gen2 block with:
    - Cometic steel head gasket (thick as the original stock)
    - CP pistons (86,5mm diameter)
    - Eagle rods
    - ACL complete bearing set
    - Stainless Steel exhaust system
    - Crankshaft and flywheel balanced
    I'd like to keep the original ECU. What is your opinion about?
    Here there are some pics of the old and new engine:
    Thank you for your help
    Daniele
    Jun 2015
    Genova - Italy
    Hello
    I'm looking for the spark plugs.
    I can't find the stock spark plugs (Denso PK20R8), can you recommend an alternative solution?
    Thank you
    Daniele
    Get a set of BKR7E plugs (NGK).
    Jun 2015
    Genova - Italy
    Quote Originally Posted by 4thgenceli View Post
    I found a pdf bgb and the spark plugs recommended from Toyota are:
    Denso PK20R8
    NGK BKR6EP8
    The BKR7E are colder than the other two? Any other differences?
    Thank you
    I forget the exact difference, I think you're right in that it is a colder plug.
    It is the one that gets recommended a lot for the 3SGTE.
    I don't see any reason with what you've done that you can't keep your original ECU if you still have the Gen 2 sensors and AFM. You won't see the full benefit of the cams but other than that there shouldn't be any issues.
    If you use the original computer with that you're really going to limit yourself. I'd throw a nice megasquirt setup on that.
    Jun 2015
    Genova - Italy
    Quote Originally Posted by Nitro_Alltrac View Post
    Thank you, i didn't know that the BKR7E are recommended for the 3SGTE
    Jun 2015
    Genova - Italy
    Quote Originally Posted by MrWOT View Post
    I know, but i have a limited budget.
    Maybe one day....
    The NGK BK6RE plugs are similar to the OEM Denso plugs (spec'd out the same at least). The 7's are a bit colder plug. If you're looking to stock boost levels the 6REs would work. Any higher compression or higher boost levels you'll want a colder plug. On my gen4 3sgte I ran it on a pair of stockish plugs while running through the break-in after a rebuild. I then switched out to the 7re plugs and on the same boost level noticed a huge difference. I was running around 15lbs boost consistently and had no issues (after sorting out non-related problems lol).
    Jun 2015
    Genova - Italy
    Thank you
    If you like, I always recommend the NGK Iridium plugs. You will want the BKR6EIX for stock heat range or BKR7EIX for one step colder.
    If you are using Gen3 cams, while it is true the ecu won't do anything for you in relation to them, you can adjust the exhaust cam 6 degrees and make some added power. Perhaps Luni will chime in to confirm that it is correct to retard it by 6deg.
    Getting a bit of additional power, I would recommend a boost controller. Preferably an electronic type. I have always been partial to my Apex-i AVCR. Others like the older Greddy Profec-B. I prefer the AVCR because it has a digital readout and you can see easily what you are doing with no guess work.
    Jun 2015
    Genova - Italy
    Thank you
    Regarding the additional power, i have a gen2 block, and i am always very fearful of a possible crack
    Jun 2015
    Genova - Italy
    Spark plugs arrived this morning
    Jun 2015
    Genova - Italy
    Hello everybody
    Unfortunately the engine work has stopped. I'm out of town for work and i'll be back after Christmas.
    I would like to take this opportunity to ask you a question: do you think that 9 is a good compression ratio?
    Some friends of mine told me that it's too high....
    I wish you a good weekend (here in Italy is holiday on December 8)
    Daniele
    What octane fuel is available and goal? Sticking with CT26 with at least 91 available, no problem @ 9:1
    Jun 2015
    Genova - Italy
    Hi
    Here in Italy i can choose between 95 and 100 octane fuel.
    Yes, i'll keep the CT26.
    As long as that number is (RON+MON)/2 you're more than okay. CT26 only blows hot air over 16-17psi. Will be perfectly fine @ 9:1 on that kind of octane. Don't see your intercooler anywhere? Would invest in 185RC or 205 WTA top mount.
    What advantages powerwise will a Megasquirt bring on this type of setup? Just curious, I have a build with similar components underway. I know the MAF can be eliminated...
    1990 Celica AllTrac - - - 1993 Celica ST
    Nothing good about the factory systems at this point. No way in hell the air meter calibration is good, it's bad even in the remans I've seen. If it's never going to see a different turbo, stock and deal with the meter somehow.
    Jun 2015
    Genova - Italy
    I have a limited budget, so i'll keep the original IC for now.
    What do you think about all those front mount IC kits i see on ebay?
    The piping or the intercoolers as well? The intercoolers do the job but the end tanks tend to be small compared with higher quality options. The piping isn't 'plug and play' from what I've heard and requires some custom fitting depending on your route you choose. I plan on getting my piping kit there and then sourcing a better intercooler.
    Jun 2015
    Genova - Italy
    Quote Originally Posted by Freelancer View Post
    Both
    Jun 2015
    Genova - Italy
    Something is moving, very slowly
    Yesterday night we mounted the intake manifold, injectors and the wiring.
    Anyway, i noticed for the first time a modify on the turbo, here it is:
    There are two pipes, one on the front (in the picture, where the metal cover is cut) and one on the back of the CT26.
    What do you think it is, a custom water-cooling modify?
    Jun 2015
    Genova - Italy
    Any opinion?
    maybe they cut the heat shield because it was rubbing on and damaging the water cooling line? im not positive but i think my old ct26 had water lines stock.
