Results 1 to 13 of 13
    Default Camber kit help...
    So I got some Meagan racing adjustable coilovers and I'm trying to find a camber kit for my rear and front. But to be honest idk where to look, what I'm looking at or for or even what brand is the best for your buck. I read mostly just camber bolts for the rear but that seem too good to be true to just need only bolts for rear camber.Need some opinions and info
    Sent from my iPhone using Tapatalk
    Front has plates already, for the rear most I use the Eibach bolts on my 5th gen.
    Yah I haven't put the Megan racing coilovers on yet cause I wanna put everything on a once. So I haven't looked to see if it has camber adjustment for the front yet. But all I need are them bolts and should be good for the rear?
    I was thinking about getting this... Seems better. Think it's for front and rear too
    The Eibach kit is just two bolts. They say the same bolt works front and rear, it doesn't.
    So am I gonna need 2 bolts for each wheel?
    No, one on each wheel, directions are included on the box. If not, use the top hole on the strut to wheel.
    Ok so I just need four bolts total, gotcha!
    Which Megans did you get? Some of them have front adjustable camber on the strut mounts themselves. If so, you'd only need 2 bolts. Just make sure to get an alignment after and they'll set the camber with the bolts. Depending on how much you lower, they may or may not be able to get the #s in spec with bolts alone.
    The Eibach kit is two bolts. One for each side. You use one bolt on right top, and one bolt left top.
    My Megans had adjustable camber plates. I didn't know that Megan had a model that didn't.
    Quote Originally Posted by kazmania101 View Post
    What everyone else has said. I only need front camber bolts due to what is likely unreported front end damage. My driver side camber plate is fully tilted towards the driver side (positive camber) and yet had a -2.5 camber, when the passenger side is fully tilted toward the driver's side (negative camber) it also had -2.5 camber.
    You sure the ride height is the same on both sides? Also, have you done a corner balance?
    Measured height, within 1/16" on several flat surfaces. No corner balance because shit is money I don't want to put down right now (budget living ftw).
