    Default ST185 Passenger Side Engine Mount
    With redoing the mechanicals on one of my ST185's, I have decided to replace all the engine mounts. Three of the 4 are available through Toyota parts, but one (the passenger side mount) is not. That mount is Toyota Part No. 12362-74140.
    I'm finding it difficult to find even an aftermarket engine mount for the passenger side of the ST185. Have any of you ever replaced one of these and, if so, where did you get your replacement engine mount from?
    The ST184's passenger side engine mount is 12362-74120 - is that mount interchangeable with 12362-74140? There are many 12362-74120's still out there (for the Celica's with the 5S-FE 2.2L engine). I'm thinking they are not interchangeable.
    If anyone has a solution to a replacement ST185 passenger side engine mount, let me know where you got yours from so I can copy and do the same.
    Amayama.com lists it as available, $91.86 +shipping, genuine Toyota...
    Sent from my LG-H812 using Tapatalk
    Quote Originally Posted by ChrisD View Post
    Yes, many online Toyota parts places lists the 12362-74140 as being available, but once you ask them to check availability, they all responded back that it is not.
    I did find out the 1991-1993 Celica convertible mount interchanges with the All-Trac mount perfectly - the only difference being the stay stud included with the mount housing. The stay stud can be removed, so swapping out the old mount stay stud and putting it into the new mount will result in an identical part. So I have one of these on order. I think that will resolve my need. Will advise if it works or not when I do the work over the next month or so.
    Update (2016-07-24): The 91-93 Celica convertible passenger side engine mount did work on the All-Trac with the simple stay stud change. No issue. Something to keep in mind in case your All-Tracs need a passenger side engine mount replacement, get the convertible mount. Note: Not that many convertible mounts out there any more either!
