Page 2 of 2 FirstFirst 1 2
Results 26 to 37 of 37
Thread: V6 celica
  1. #26
    Damn!!!! Love this project. Great work.
  2. #27
    I wanted to make it easy on myself and not remove egr until i get the engine running properly in stock form. the egr tube is hitting the steering rack.
    I guess egr delete here i come!!!
  3. #28
    Nicely done! Thank you for sharing your progress.
  4. #29
    Update on the GT6. (yes this is what i'm calling it)
    i've decided to let somebody else do the exhaust, i'm not that great at welding and found a local guy that came highly recommended.
    i am extremely happy with the results, and yes true dual all the way across,
    one shot of the 1mz
    also i think i found a way to turn the celica fuel system into a returnless,
    lexus had the regulator in the tank, so i moved the lexus pump and regulator in to the pump housing from the celica,
    here is the lexus pump housing with pump and regulator removed
    here is the celica pump housing with the lexus pump and regulator, the pump on the right is the original from the celica,
  5. #30
    I bet that is a hoot to drive.
    HA HA HA !!!
  7. #32
    It didn't start, did it?
  8. #33
    Nice work.
  9. #34
    Awesome. Love v6 swaps! GT6, right on.
  10. #35
    Finally it started, here is the vid.
    https://www.youtube.com/watch?v=9Kut0uASEtE
    also had a question about the transmission. as you can see in the video on the cluster non of the "PRND" letters are lit up and it throws trans position codes, the automatic trans plugs are simply disconnected, i know that if you're in park it should only rev to 4k, as you see it revs all the way to redline. since the starter runs of the original celica ignition, i have no need for the neutral safety switches etc. will the engine operate normally with the trans unplugged.
  11. #36
    Nice work! I'm not sure about the trans stuff but I imagine that'll be a blast to drive.
  12. #37
    If you are getting a full rev range out of the engine it should perform fine with that plug undone.
    Great job!
    Originally Posted by vafalla
