    Default 3SGTE Crank Bearings
    I was wanting to check to see if this is a valid number for the bearing set:
    1170463022
    If so, is this set available?
    Thanks.
    CelicaTech Vendor FrunkMonkey is on a distinguished road
    Oct 2010
    Eugene, Or
    That part number is for a 5SFE and are .25mm over sized. Are you wanting oversized bearings? If you are just wanting stock sized main or rod bearings you will have to figure out which "mark" each position on the crank or rods have. The numbers can be 1-5 and can also depend on which journal they are on. Refer to the BGB for where the numbers are located.
    -Tracy
    Tracy Griffin - Lithia Toyota of Springfield, OR -
    '91 T-Top N/A MR2
    Get prices and order online. Check out the new LithiaToyotaParts.com!
    Thanks. I'm looking for stock size bearings.
    I got that number from a another dealer site and wanted to check with you first.
    11071-88360-01 mark 1, no.3
    11071-88360-02 mark 2, no.3
    11071-88360-03 mark 3, no.3
    11071-88360-04 mark 4, no.3
    11071-88360-05 mark 5, no.3
    11701-88342-01 mark 1, no.1, 2, 4, 5
    11701-88342-02 mark 2, no.1, 2, 4, 5
    11701-88342-03 mark 3, no.1, 2, 4, 5
    11701-88342-04 mark 4, no.1, 2, 4, 5
    11701-88342-05 mark 5, no.1, 2, 4, 5
    BEARING SET, CRANKSHAFT 11704-88361 U/S 0.25 (.25 oversized)
    Those are all the possible part numbers for your bearings based on your cap numbering. So find your numbers, then order the correct ones
