Results 1 to 25 of 31
    Jul 2006
    monroeville alabama
    Default My MR2 V6 thingy
    So I decided I want to do track days in my MR2. My 400whp 3S couldnt deal with the heat well enough so I decided to pull it out and put in a reliable RAV4 2RG instead. Here are some pics and notes. As of 2/24/15 it cranked up and ran but I still have a few things to finish like the exhaust and AC lines.
    Started with this
    Added this
    Took everything out
    Put some things together.
    Used a 1GR AC compressor. Bolts right up and is controlled just like the MR2 AC was.
    Built a Midpipe. 2.25" primary into 3" collector. Pipe from Mandrel-bends.com
    Wired up using a 2006 RAV4 ecu and 2008 harness. I replaced the MR2 fuse box with a Corolla small box with several modifications to the wires and routing .
    Axle 1/4 spacer. Worked great
    Jul 2006
    monroeville alabama
    Used 5/8 braided hose for the heater core. Coolant nipple cap was from a 2zzge block. Drivers side radiator hose number is Gates 22306. Passenger side Gates 21701 and needs trimmed at the bottom. Coolant neck hose Gates 20896 and is trim to fit. I use a custom neck with a Morosso 19-21 psi cap. Fuel line was an aeromotive startlite -6an . It fit the stock barb well enough.
    Grinding to fit the E154 (converted st205 trans with TRD LSD)
    Installed AN fittings onto a seinna upper pan. The right side is the outlet, lef the inlet.
    Used a canton thermostat and the cooler i used with my 3S.
    2008 Camry CAI off of ebay. The pipe needed a lot of love but it works now. Air filter is a honda prelude and has a 3" outlet.
    Mounted a Mercedes OBDII port next to the engine cover latch. It is probably the most fancy port Ive ever seen. It is recessed and has a door that snaps shut!
    More to come later!
    What are the odds of this fancy beast coming to play this year, will it be done in time?
    Jul 2006
    monroeville alabama
    Since its my only Toyota, the is are good. Also since the last pic is a screen shot of it running.
    Quote Originally Posted by donteatbugs View Post
    Chaos runs, doesn't mean she is going to the Dragon.
    But don't tell her, it will break her heart.
    May 2006
    Castle Rock, CO
    That's freakin' cool.
    Jul 2006
    monroeville alabama
    I just finished this last night but my cheap vband clamp broke. I also tried to bleed the coolant and I cant seem to get the water to flow? I think there is air trapped in the water pump but the thermostat opened fine but all my pipes statyed cold, even the heater was cold. I did have coolant at all the bleed screws though. Im almost ready to buy a new water pump though.
    Mar 2005
    Looking great.
    2012 Jeep Wrangler
    1993 Mr2 Turbo
    Originally Posted by vangls14
    Very cool setup, how hard was mounting that in the 3S bay?
    Jul 2006
    monroeville alabama
    With goukys kit it mounted easier than the 3s.
    So is it now easier to retrofit a V6 into a 3s car (MR2 or GT4) than simply going up generations of 3S?
    If so, that is awesome.
    Jul 2006
    monroeville alabama
    It not cheaper, but it is fairly easy. I did start with a highly modified setup already. I like the stock way this thing cranks and idles. I cant wait to finish the suspension and put her on the road.
    Nice work, Bugs.
    Jul 2006
    monroeville alabama
    A few notes on the Alternator wiring. RLO does not work on the Seinna alternator. It needs the 12v ALT-S wire. I cut the RLO wire from my ecu harness and tied it straight into the ALT-S wire and my charge light went away.
    I also inverted my CEL so it stays off all the time unless there is a flashing code. I used a PC mount 12v relay with a ~200 ohm coil. I used the IG wire to power the coil and the ECU W to ground it. It wont work with a 120 ohm coil. W has a very small current capability. I tied the Dash CEL to the NC contact and the common to ground. This will still flash the CEL in case of problems but keeps it off with a steady CEL.
    I weighed my finished rear exhaust section at 22 lbs. Its slightly longed than the Berk section as it goes over the crossmember. My Berk weighed over 28 lbs for just the rear part. I took a video but it sounded terrible inside my car port. The exhaust sounds really good free reving and is so quiet I can hear the engine over it at idle.
    I didnt get much done this weekend. I did finally get the coolant to start moving by cracking the hose before the thermostat to let all the trapped air out of the system until it opened. Also hung the exhaust for the test fit. only a little hammering needed on the brackets and everything fit.
    So my swap is 90% done now. The main things I lack are Cruise control and AC lines. I got a little distracted before I finished my wiring and made some short stroke front shocks. 8611-1257 koni on 7" 13k springs and no sway bar. They are awesome and well worth the money.
    Some pictures of the obd2 port, CEL relay and fuse box I used.
    Fantastic job Bugs. Really, really well done.
    Normally aspirated. So 90's.
    j/k That's pretty sweet.
    mmm torque!
    Originally Posted by vafalla
    Fuckin A. Cant wait to drive this thing sometime.
    Maybe next year.
    So why are you not going again? Plans changed in regard to work schedule or?
    Because Im trying to save money for a house and to get my life moving in a direction I need it to go. The dragon is expensive, any way you cut it. Its just not needed. I cant justify it.
    Awww, my little Papa Bear is growing up...
    Yeah, when are you going to actually join society and buy some property you fucker?
    Fuck the establishment.
    May 2006
    Castle Rock, CO
    Pay cash for a house then.
    By renting, you give your money TO the establishment with no expectation of a return. I may be giving my money to the establishment too, but at least I'll be able to see some of it back...
    Jul 2006
    monroeville alabama
    https://youtu.be/C7AtW7ZAbgo
    Exhaust video for sound
