    Default ST205 removal front driveshafts
    I have a small hole in the rubber casing that protects my driveshaft on the left side. Right side has to be changed too.
    How do I remove the driveshafts so I can change theese casings?
    Remove the axle nuts, you will need a 30mm deep socket. Drain the transaxle fluid. Then disassemble the suspension enough to get the shaft out of the hub and then it just pulls right out of the transaxle.
    I think I only had to disconnect the upper ball joint, figure 8 link, and steering tie rod end to get it out.
    Don't forget to have a front alignment done afterward, as you disassembled your suspension.
