Results 1 to 6 of 6
    Default st165 hub/bearing question
    So, I am about to try and replace the front bearings on my alltrac and I am going to assume that my hub is damaged also.
    Is this all I need for bearings and seals?
    2x https://www.rockauto.com/catalog/mor...003&cc=1273991
    (https://www.rockauto.com/catalog/x,c...,parttype,1672)
    2x https://www.rockauto.com/catalog/x,c...,parttype,1860
    I assume just ordering 2 kits that have the inner, outer and retainer.
    Can I use these hubs potentially? Not concerned with ABS functionality as that will just have the fuse pulled anyway.
    http://www.ebay.com/itm/Front-Wheel-...ff35e9&vxp=mtr
    or
    http://www.ebay.com/itm/WD-Express-3...b8d011&vxp=mtr
    (I am just assuming my hubs are toast) Also, are the bearings the same between the trac/celica/camry?
    One hub specifies alltrac, while the other says celica and camry. Not sure if they are different.
    Thanks for any input.
    Oct 2006
    Minot ND
    Lemmi do some remembering. The 165 I bought has toasted hubs all around and it seems like what I found was the 165 is different from everything else. I'll get back to you soon
    Originally Posted by manda
    89 Celica GT
    88 ST165 "
    07 4Runner SR5
    Oct 2006
    Minot ND
    Check out this when I asked Lithia about them
    http://www.celicatech.com/forums/sho...rac-Front-Hubs
    Part number 43503-32020 for the hub shows to fit several Camry's so maybe the ebay ones will actually work.
    If it'll help I can take my hubs off again and measure stuff. Mine fall right apart because the bearings are toast and damaged the hub as well so it's an easy job lol
    89 Celica GT
    88 ST165 "
    07 4Runner SR5
    http://oemparter.com/oem-parts/43503...roup=726659298
    Think you are right. This site leads me to believe that the part is from a Camry or Celica, with ABS, then it will work. Very promising.
    Oct 2006
    Minot ND
    I know, sometimes my awesome exceeds even my own expectations
    89 Celica GT
    88 ST165 "
    07 4Runner SR5
    Well, since I can't say with the most confidence that the ebay ones will work, I will get the bearing and seals from rock first and just see how my hub is.
