    Default St185 suspension bushings
    Looking to replace all my suspension bushings
    http://m.ebay.com/itm/321508271981?nav=SEARCH
    Is this everything?
    I will also be buying oem spherical bushings.
    Where is a good place to buy motor mounts?
    What about the side mounts that support the weight of the motor/trans?
    Swaybar bushings, front lower ball joints, endlinks and tie rods (inner and outer) would be a good addition to those.
    So what's listed in the picture is a pretty good start?
    I don't track the car, hope to someday but it's not barely stable when driving around town so no sense in throwing it on a track or autox course that it can't handle.
    How will this setup be for daily driving?
    If you don't track the car, I wouldn't put in poly. It really firms up the car a lot and you'll feel the little imperfections in the road a lot more. I'd see if anyone makes rubber replacement bushings.
    You can get OEM quality rubber replacements on rockauto.com for some sweet prices. Some items are even Aisin, Denso, Koyo and other factory manufacturers.
    I'm not a Jackass whisperer.
    Thanks for the heads up. I'll take a look for some replacements other than poly.
    Did you or anyone else find somebody selling a kit with rubber instead of poly? Can you provide link(s)? Thanks, my ride is in dire need.
