Results 1 to 11 of 11
    Default R154 clutch hub stuff
    As the title states, I need the clutch release hub, snap rings, washers, etc. for an 87 supra 5spd... and a new release/slave cylinder. Um.. might as well price the master cylinder while I'm at it.
    Oct 2010
    Eugene, Or
    Everything is available-
    31470-14050 CYLINDER 64.40 (SLAVE)
    31410-14193 CYLINDER 118.30 (MASTER)
    31231-14040 HUB, CLUT 55.26
    90363-45012 BEARING, 29.35
    96152-00450 RING, SNA 2.11
    90201-71001 WASHER, P 1.39
    90206-72001 WASHER, W 1.12
    90520-67001 RING, SHA 2.94
    31264-14040 SPRING, C 15.81
    '91 T-Top N/A MR2
    Thanks! When not broke, will order
    Also if I could get PNs for 2zzge:
    Timing chain
    Timing chain sprocket/gear (on crank that timing chain goes on)
    Whatever the brass colored disk is that goes on the crank after the timing chain sprocket and before the crank pulley.
    Oct 2010
    Eugene, Or
    Here you go-
    19315-22020 PLATE, CR 7.32
    13521-0D010 SPROCKET, 12.81
    13506-88600 CHAIN SUB 166.34
    '91 T-Top N/A MR2
    Hmm, can't seem to order this time, keep getting an error message on the form "8673834"
    Oct 2010
    Eugene, Or
    They have been doing "maintenance" on the site. It was working this weekend and just have an order come through a little bit ago. If it keeps giving you problems just give me a call.
    1-800-888-6305
    Tracy
    '91 T-Top N/A MR2
    I called in a few days ago and they said you were out but that they'd corrected the issue, so hopefully the order is processing
    Quote Originally Posted by VavAlephVav View Post
    I bought an Aisin clutch kit with the disk, pressure plate, and the release bearing for $130 on rock auto. all they do is take a grinder and erase the Toyota emblem
    Actually, what they do is probably just buy an Aisin pressure plate like most aftermarkets do. My competition clutch has an Aisin pressure plate with upgraded springs. In this case, the parts I ordered weren't a clutch kit, they have to do with the funky pull-type clutch release that my transmission uses, and that's not the sort of thing I'd buy aftermarket unless it was an upgrade of some kind. Also, while I'm sure you mean well, it's not generally cool to come into a thread in a vendor's forum and post "competing" prices or places you think people should buy from instead. I buy from Lithia because they support the community and it's genuine Toyota parts. May not mean much to everyone, but it does to me.
    PS: Toyota owns AISIN...
    sorry I wasn't paying attention.
    I'm not a Jackass whisperer.
    May 2006
    Castle Rock, CO
    All good. Just a note for next time. Off topic, craigslist finds, and WTB forums are generally ok for that. We separate off the vendors because they do help keep the lights on over here.
