    Default 2zz timing cover gasket
    Hi, could I get the part numbers for the 2zz timing cover gasket, chain tensioner o-ring, front crank seal, and valve cover gasket?
    Thanks!
    Oct 2010
    Eugene, Or
    13540-88600 TENSIONER- They do not list the seal seperate. Tensioner isnt to expensive or try and match up the o-ring.
    11193-15010 GASKET, S X 4 SPARK PLUG TUBE SEALS. IF YOU NEED THEM
    11213-88600 GASKET, valve cover
    11328-88600 GASKET, Timing
    11329-88600 GASKET, Timing
    90080-31049 SEAL, TYP
    '91 T-Top N/A MR2
    Thankya sir
