Just wondering if the Arp 3sgte Head and main studs will work on the 5sfe engine? Ive seen and herd of people swapping the heads from the 3s on to the 5s block.
Im building motor to hold turbo. Ill be having custom pistons made. How much boost should I plan on running If I want to get to the 350-400 HP range. Machine shop needs to know. I told them a possible 30 pounds.
T3T4 turbo set up will be done.
All professional work will be done on the motor.
