Results 1 to 11 of 11
Thread: 2zzge pcv
    Default 2zzge pcv
    Yo, could I get part numbers for the pcv valve and the hose that connects it to the TB? (If there's any other part of the PCV system I'm not thinking off, I'd take PNs for those too)
    Thanks!
    Oct 2010
    Eugene, Or
    12261-88602 HOSE, VEN
    12204-88600 VALVE SUB
    12262-88603 HOSE, VEN-second hose that runs next to main PCV hose.
    There are other pieces on the opposite side of the engine for case ventilation. not sure any of that would be needing to be replaces though. If so I can get the numbers for you.
    -Tracy
    '91 T-Top N/A MR2
    Great, ordered. Thanks! (I won't mess with the ventilation on the other side if I don't have to, it's all cozy with the firewall )
    Weird.. the PCV hose fit, but the other hose doesn't at all. The nipple on the TB is much larger than what the hose will fit on. Apparently that hose is different for different 2zz years/vehicles. Too bad I don't know what my engine came out of!
    Oct 2010
    Eugene, Or
    I am going to say that you have an early engine. The hose I sent fits the middle of 02 through 05. The other is 00-02.5. If the hose and packaging is in good shape and its worth it you can send it back.
    -Tracy
    '91 T-Top N/A MR2
    Ah, that makes sense. I'm pretty sure I still have the package and can ship it back. My original hose is cracked so I'd like to replace it if I could swap for the correct hose and of course pay any difference.
    Yours is '00 or '01 based on the pics of the old lift bolts. FYI.
    Oct 2010
    Eugene, Or
    No problem dude. Get it headed this way and I will get the right one coming.
    -Tracy
    '91 T-Top N/A MR2
    Oct 2010
    Eugene, Or
    I just received the incorrect hose and got the other on order. I should see it in a couple days. The one you need is cheaper so you are covered for shipping too.
    Thanks, Tracy
    '91 T-Top N/A MR2
    Ah, awesome, thanks!
    BTW, on an unrelated note and just for grins.. for the 87 supra, is the brake light control box that mounts by the left tail-light assembly still available, or are they discontinued?
    Oct 2010
    Eugene, Or
    It is still avilable. 89373-32120 SENSOR- $194.00
    '91 T-Top N/A MR2
