Results 1 to 6 of 6
    Default Small part list!
    Howdy, I need the following part numbers to order:
    For 87 Supra
    R154 bellhousing to engine bolts
    Pressure plate to flywheel bolts
    Right side bellhousing access panel/service port cover
    R154 rear seal (for propeller/drive shaft)
    R154 to chassis bolts - holds the bracket to the car that the transmission mount sits on
    Thanks!
    Oct 2010
    Eugene, Or
    And here you go....
    90119-08A87 BOLT, W/W 0 4-Cross member to frame
    90080-11228 BOLT, W/W 0 4-trans mount to cross member
    90311-40001 SEAL, TYP 0 1
    90119-08782 BOLT, W/W 0 6
    90080-11228 BOLT, W/W 0 1
    31102-14010 COVER SUB 0 1
    90119-10019 BOLT, W/W 0 4
    all available.
    '91 T-Top N/A MR2
    Tracy, thanks as usual for the assistance. Just to clarify, the 31102-14010 is just the little metal plate held on by two small 12mm bolts on the side of the bellhousing? I ask because it's way more money than I'd have expected, and if that's the correct part number I'll have to just bend/patch mine up as well as I can and re-use it. Thanks!
    Oct 2010
    Eugene, Or
    You are correct, jsut a small piece of tin. Time to fix what you got.
    -T
    '91 T-Top N/A MR2
    Gotcha, just wanted to clarify. Obviously it's not your fault it costs what it costs, but I'll fix mine Ordering the rest shortly. Thanks again!
    Oct 2010
    Eugene, Or
    That's one of those, what the hell are they thinking!? Moments. Kinda like asking 80.00 for a plastic hub cap.
    '91 T-Top N/A MR2
