Results 1 to 25 of 33
    Default Turbo not boosting till about 5000RPM
    The Ogopogo pics inspired me. Took a look on the RC today, removed intake and spun the compressor wheel of the turbo freely with no shaft play whatsoever. So why am I not getting any boost until about 5000rpm? and the boost max is like 10 where normally it should boost 16psi with no effort.
    Some info on the turbo and when it happened, Its a CT26 with an MBC from twosRus. I was boosting for a long period of time, then It happened suddenly and not over time, the boost point changed from 2800-ish to 5000-ish, and the boost would reach 10psi max.
    I suspect it would be something to do with the wastegate, an exhaust leak before the turbo (but that would have to be major, wouldnt it?), or something with the MBC (that would explain the boost peak, but not the RPM range).
    Any opinions would help.
    94 JDM ST205
    94 JDM SW20
    91 JDM ST185 RC
    When I had an exhaust leak after the turbo. It still spooled but surged horribly. I would guess mbc. Try turning it all the way down and see what happens.
    I would have to agree with something being off with MBC. I'd start there anyway. I was doing some maintenance on mine recently and found that I had a nut missing off of the stud holding the turbo to the manifold and then found that the other 3 nuts were loose as well. I had to have an exhaust leak there but I didn't have any noticeable boost issues.
    Can you replumb the stock system to the wastegate? If you took the MBC out of the picture completely that would answer the question anyway.
    I was thinking of putting it back to stock boost control also. I think that will be the next step to take. I think I might put her together after that and go for a quick spin. If that doesn't solve it, I'll look for an exhaust leak.
    I just had another thought..., it might be the wastegate, or actuator, so I'm thinking of putting pressure with a hand pump and check that. What do you guys think, waste of time? or possible cause?
    Thanks guys! all input is appreciated.
    94 JDM ST205
    94 JDM SW20
    91 JDM ST185 RC
    Hoses are put back to stock, and the mbc has been removed completely, however, boost has been unchanged. Very very laggy and low boost.
    Im done working on it for today, I need to get out and get me some...
    Cheers!
    94 JDM ST205
    94 JDM SW20
    91 JDM ST185 RC
    The only other thing I can think is that your waste gate is cracked open and won't seal tight. That would case all your boost to flow out until your moving enough air to actually build boost.
    If you have access to an air compressor and a vacuum pump, you can test the function of the waste gate.
    I have both, thanks, I'll check that tomorrow after work.
    94 JDM ST205
    94 JDM SW20
    91 JDM ST185 RC
    Good deal. That will make your life much easier since you can actually test things without having to take it all apart and just guess or hope to see something obviously broken.
    Should take you about half an hour to test and verify results.
    Fingers crossed that it's something small.
    Ultimo Miembro Fantįstico Gigantesco MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of MrWOT has much to be proud of
    A blown diaphragm causes overboost, because it doesn't actuate the flapper. You need to pull the downpipe and inspect the hot side.
    Sounds like symptom of the WG arm disconnected from flapper (possibly - although usually your boost is MUCH lower with that) OR, more likely, clogged cat.
    What kind of exhaust system do you have on that thing? Do you even have cats?
    Shouldn't clogged cat spool really quick but have no power?
    It sounds more like the arm being off [like you said], or the WG broken open or something.
    Blown up hot side should be no boost at all. And if it's an RC turbo it's a steel wheel anyways.
    And FYI, the MBC would either cause stock boost or too much boost.
    If the MBC broke and allowed boost to pass early it would just go to the WG actuator and you would get stock boost.
    If the MBC broke closed you would get boost until you hit boost cut.
    Did you do any work on the car before it did that?
    Does it run hot at all?
    How's the timing?
    Jeremy, when the cat was clogged in my MR2, it spooled slow as fuck. It only got 4 PSI and it took FOREVER to get there.
    Yeah, I'm not sure on that [which is why I question marked it ].
    I know that exhaust gas slow down would gives you quicker spool and more torque at a lower RPM.
    I wasn't sure about something that extreme though, and I've never dealt with it with a turbo.
    Too bad you live in the miggle of the goddamn mountains, I think it would be good to have a beer together.
    Or 20.
    Well, my company has a datacenter in Andover. If I ever get sent out there. Im calling you up.
    When my cat clogged on the Supra, it gradually was able to build less and less boost, then finally no boost, then unable to rev well, and finally unable to rev high enough to even maintain highway speed. Exhaust issue is one of the first things I thought of when I read the original post. On mine it was really simple to test, because it was just one vband clamp and the exhaust was completely out of the loop. On a stock 3sgte system that's a lot more annoying to test, obviously..
    Andover, huh?
    Stay away from Lawrence.
    Yeah, give me a call.
    Just give me at least a few days heads up. I work nights and have 2 little wild animals at home.
    So it's hard to escape without making plans.
    Have you checked for an intake/boost leak?
    Could also be cam timing as well.
    Could be your FACE Joey!
    No cat. I think it has an ebay dowpipe but it works. Im going to take it off, Inspect dp and turbo as soon as I can. Its my RC, but not sure about the impeller being ceramic or steel. I have replaced the motor with another RC motor, and it seems to runs warm to the touch (compared to my mr2 and 205) but the temp gauge shows normal.
    94 JDM ST205
    94 JDM SW20
    91 JDM ST185 RC
    It runs strong with no boost...still might be worth a quick check before ripping off the turbo and dp .
    94 JDM ST205
    94 JDM SW20
    91 JDM ST185 RC
    Also. I removed the mbc and its still driving exactly the same. Compressor wheel spins smooth with no play.
    94 JDM ST205
    94 JDM SW20
    91 JDM ST185 RC
    Taking the downpipe off today, to inspect the wastegate and dp I found the o2 sensor wire cut and disconnected. Could this effect my boost? I picked up a replacement (ct26)turbo in case I need it. I ran out of time to complete the disassembly of the turbo.
    More to come tomorrow.
    94 JDM ST205
    94 JDM SW20
    91 JDM ST185 RC
    Sounds like your wastegate may be stuck open...
