Thread: 3VZFE Rebuild
    Default 3VZFE Rebuild
    I need the following PN for a 93' Camry XLE V6:
    Rod Bearings
    Main Bearings
    Piston Rings
    Head Gaskets
    Engine Seal Kit
    Head Bolts
    Thanks!
    Oct 2010
    Eugene, Or
    I need to know what mark on the rod bearings along with what mark and position of the crank bearings. That is unless you are going 0.25 oversized on the bearings.
    Stock or oversized on the rings?
    -Tracy
    '91 T-Top N/A MR2
    Hold off on the bearings for now.
    Stock rings, as the cylinder walls were just rehoned.
    Oct 2010
    Eugene, Or
    13011-62060 RING SET 233.39
    90201-11028 WASHER, P 0.96ea. x 16
    90910-02077 BOLT 5.06ea. x 16
    04111-62050 GASKET KI 316.71- complete gasket set
    -Tracy
    '91 T-Top N/A MR2
