Thread: Some MRS parts
    Default Some MRS parts
    2001 MR2 Spyder 5spd:
    TO bearing for trans (and input shaft/support bearing if it has one, but think so)
    Bolts and springs for midpipe to muffler connection
    "donut" gasket for midpipe to muffler
    2zzge exhaust manifold to head gasket(s)
    Thanks!
    Oct 2010
    Eugene, Or
    Here are your numbers-
    -31230-12191 BEARING A
    No pilot bearing
    Bolts and springs for midpipe to muffler connection-
    90501-A0031 SPRING, C 2
    90080-10291 BOLT 2
    "donut" gasket for midpipe to muffler-17451-22060 GASKET, E
    2zzge exhaust manifold to head gasket(s)-17173-88600 GASKET, E x 1
    Thanks!
    '91 T-Top N/A MR2
    Howdy, could I get some more part numbers? (this is for installing an LSD into the stock MRS 5spd)
    two taper differential bearings
    two differential/axle seals
    I assume L and R are the same, but if not, need numbers for both sides
    Oct 2010
    Eugene, Or
    90366-40094 BEARING, LH
    90366-40129 BEARING, RH
    axle seals if you need them too-
    90311-35064 SEAL, TYP
    90311-35065 SEAL, TYP
    -Tracy
    '91 T-Top N/A MR2
