Results 1 to 2 of 2
    Default Couple items to order
    I seem to be unable to access my account...could you look into that? Email is tim@ourlewisfamily.net.
    Second, what's the availability on the following:
    Pressure plate -> flywheel bolts (P/N 90119-08026)
    Transmission -> motor bolts (how many are there?) I took 3 out when I took off the transmission, I'm pretty sure I had more than that when I installed it....
    throw out bearing and spring (P/N 31232-20031 and 31230-20190)
    pivot ball for the arm (P/N 31236-20070)
    ^^^^Those would all be for a 95 MR2 turbo (3sgte/e153)
    Inner and outer front CV boot clamps for a 1989 Celica Alltrac. Also the 4x bolts for the north/south crossmember (should be P/N 91651-61060)
    Oct 2010
    Eugene, Or
    Not sure why your account no longer exists. You can create a new acount or give me a call and place your order.
    -Tracy
    90080-11310 BOLT, W/W 0 3 1.61
    90080-10082 BOLT, WAS 0 1 0.68
    91651-41022 BOLT, W/W 0 1 1.39
    90105-10077 BOLT, WAS 0 1 1.39
    ^^^^motor mount bolts^^^^
    90119-08079 BOLT, W/W 6 0.59
    31232-20031 CLIP, REL 1.61
    31230-20191 BEARING A 30.36
    31236-20070 SUPPORT, 10.31
    42345-16030 CLAMP, RR 2 3.46
    42345-16070 CLAMP, RR 1 6.76
    90949-01340 CLAMP 1 2.54
    91651-61060 BOLT, W/W 4 1.44
    '91 T-Top N/A MR2
