Results 1 to 22 of 22
    Default 5sfte Track Questions
    Hey guys, I recently had a 2000 GT-S and was able to get 15.0 at the track. How much PSI would i have to run on my 5sfe to get to that at least?
    i would think about 8 would be able to get that easily, ive seen a guy here in town wit just intake exhuast, and advance timing pull a 16.2
    i miss my celica
    Smile
    i ran 16.01 wit intake exhaust n a new exedy clu tch
    I'll let you know pretty soon. I should be going to the track soon now that its opened. Hopefully I should put down some good numbers if I can get traction. If not, I've got a few tricks up my sleeve for this summer.....
    Website is up and running again:
    I'll probably go next Friday.
    -Twin Entry CT-26 & manifold
    -JDM MKIII Supra intercooler (different endtanks than USDM)
    -2.25" intercooler piping
    -7MGE light green tops
    -2 bar map
    -MSD BTM
    -2.5" Brullen cat-back
    -custom 2.5" Midpipe
    -stock downpipe w/ gutted cat
    -no boost controller and no plans for one w/o upgraded internals/tuning
    -boost anywhere from 7-9psi summer and 12&up in winter depending on temperature (fuel cut set at 12psi)
    wow cant wait to see what kind of times i can be expecting. good luck
    Hey Shreindogg, a boost controller will help you even set at 12 psi. It will help the boost to come on faster.
    Quote Originally Posted by schreindogg
    -2 bar map
    -MSD BTM
    that setup and your wondering if your gonna hit 15s???
    try low to mid 14s
    Good luck with it though
    Where did I say I was hoping to run 15's? I've ran the numbers a few times and with a decent launch I should pull a 14.5.
    Alltracman, I've got enough boost control problems without a boost controller right now. I'd like to straighten everything out before putting one on. My friend's got a homemade ball and spring controller in his garage somewhere that I might put on later. Plus, boost comes on quick enough that I have no traction in 1st and part of second already.
    with my 1992 GT 5sfe Intake Exhaust I ran a 16.0
    I hope to get my 5sfTe up in a month or so and see what changes....I hope its not the head gasket lol
    Peace,
    TRD Terror
    Still havent got out there. The friday night test n tune just started up again on the 17th. I finally got my new Dunlop FM901's put on and I installed my new wheel bearing so after I finish welding up my new battery mount and get the box covered, I will head out there and get some times. I also have some money left over after buying the tires, so now I should be able to buy a set of S5 Rx-7 460cc injectors after I get an alignment.
    I ran a 14.7 at Famoso on 0 PSI.
    Quote Originally Posted by Celicaguy13
    any updates?
    1991 GT // Sold as Of November 30th, 2009 =(
    very intrested in numbers.. heres hoping for 13's
    wow out of all the 5sfte's out there, There are a few who actually take them to the track. Maybe therer arnt any around them..
    Still haven't got a chance to get out to the track yet. I have been so damn busy with work, I have missed every test 'n tune at the track. I have worked almost every Friday evening since I got hired. My downpipe still isnt in yet, but I hope to have it on before I go the track. I promise to get you guys some numbers as soon as I run it. I might even get enough money by then to get the Ultimate E-Manage so I can do some tuning while I'm there.
    I went to the track yesterday to see what I can get before the turbo, but My clutch is SLIPPING! I was only able to go twice but the first time I missed 3rd gear and I hit a 17.3, and on my 2nd try "clutch almost gone" I hit a 16.5 with a crappy launch i think it was like a 2.4 60ft. Anyways all I have for upgrades is a crappy custom sri. Cant wait to see what a turbo and stage 2 clutch will put!
  1. A list of Celica magazine articles
  2. 5sfte oil pressure questions
    Last Post: 11-16-2005, 06:01 AM
  3. 5sfTe update.. progress is being made..=)
    Last Post: 11-16-2005, 02:55 AM
  4. Questions about interior lights?
    By Ohjay in forum 5th Generation
    Last Post: 10-25-2005, 03:47 AM
  5. 5SFTE questions.
    By SilverCel in forum Forced Induction Applications and Tuning
    Last Post: 04-04-2005, 12:43 AM
