Results 1 to 17 of 17
    Default Hatch gasket/seal
    Yo, part number please for the seal for the hatch of an 87 supra turbo hardtop (I assume they're all the same, but just in case). Is it still an available part?
    Part number is 67881-14110 and there are several in the US right now and more on the way.
    Ouch, expensive sum'bitch, ain't it? Oh well, so are rust repairs.. thanks for checking! Might add it to an order in the near future.
    No worries. Is it expensive? I didn't look. But it's a low volume part for a low volume car, so it wouldn't surprise me.
    Ultimo Miembro Fantįstico Gigantesco temperacerguy is just really nice temperacerguy is just really nice temperacerguy is just really nice temperacerguy is just really nice
    Sep 2010
    Space Coast FL
    well at $75 I'm actually surprised it's not more...
    Could you look up the door seals and the sunroof seal for an ST185?
    BTW, got my RC hood sprayers! Thank you very much, they are ugly SOBs, but should blend in with the dark carbon fiber :-)
    The VIS Carbon Fiber hood Group Buy is CLOSED.
    I'm gonna go ahead and order that seal.. another puddle in the trunk when I got home While I'm at it, I need some oil filters. I'd like the JDM Toyota ones if you have'm for the supra. If so, what part number should I order them under?
    Quote Originally Posted by temperacerguy View Post
    By "door seals" I assume you mean the weatherstrip between door glass and roof, not between door shell and body. Between door glass and roof are 62381-20072 right and 62382-20072 left. Sunroof gasket is 63250-20010. Glad you like the nozzles!
    We have JDM filters for that car. Order as part number 90915-20003A. Thanks!
    Order placed. Thank you much for the quick service, as usual. I noticed at the end I forgot to update the cart after modifying the quantity on the oil filters. If you have an easy way to add two more to the order, please do. If not, it's really no problem, I'll just add them to the next order since I really only need the one at the moment.
    So you want three oil filters? No problem at all. Thanks for the order!
    How difficult is it to replace the door seals?
    Crickets. I am sure I don't know.
    Quote Originally Posted by Car_Barn_Bandit View Post
    Heck if I know. I've never replaced a body/window/door seal. This hatch will be the first, so I guess I'll find out
    Ultimo Miembro Fantįstico Gigantesco Galcobar is a splendid one to behold Galcobar is a splendid one to behold Galcobar is a splendid one to behold Galcobar is a splendid one to behold Galcobar is a splendid one to behold Galcobar is a splendid one to behold Galcobar is a splendid one to behold Galcobar is a splendid one to behold Galcobar's Avatar
    Hatch is easy -- well, assuming it's the same as my 90 GT hatch. It's really just a U-shaped piece of rubber, with the open end of the U pointed down to slip over a rim around the hatch.
    The door seals -- well, I tried pulling one off at the junkyard, and damned if I could figure out how to get it back in. If/when you succeed, a write-up would be appreciated I'm sure.
    Well poop. Fixing one leak reveals others.. part numbers for the big rectangular seals between the tail-lights tail-light pockets, please!
    Ah. Well, at least you're getting closer. The taillight gasket is 81554-14580. Two per car; the same part number is used for left and right.
    Finally ordered.
    Right on, thanks!
