Thread: spark plugs....
    Default spark plugs....
    so i changed my spark plugs today and when i took the old ones out there were two of them that had a bunch of oil on em...is it normal or does that mean something is leaking or something??
    http://www.cyclefish.com/forum/The-G...ce-3706-1.html
    These pics should give you an idea as to whats going on.
    Does the 3SGTE have removable spark plug tubes like the 5SFE? If so, the threads on those do need to be resealed every once in a while. BGB recommends blue-strength high-temp thread locker, though others on this board swear by FIPG. This is separate from the spark plug tube gaskets which are replaced at the same time as the valve cover gasket.
