Thread: Its ALIVE!!!!!
    Martinez, CA
    Default Its ALIVE!!!!!
    Well it runs, I still need to adjust the timing and the tps sensor, but it runs what a good feeling
    http://s469.photobucket.com/albums/r...=VIDEO0011.mp4
    ST165
    Awesome!
    congrats
    R.I.P Cherry Bomb (1990 Celica ST)
    They call me Hadoken because im DOWN RIGHT FIERCE
