Results 1 to 9 of 9
    Martinez, CA
    Default 3sgte timing cover sticker
    Are the 3sgte sticker for the upper timing on a 88 alltrac still available? If so is can I order one?
    Sent from my HTC Sensation 4G using Tapatalk
    ST165
    The Ultimate Celica Driver
    Proof of 14.7 required...
    vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09 has a brilliant future vip09's Avatar
    vip09 ran a 14.7 on the Dragon! vip09 has donated to the forums! vip09 helped get Grayscale's Celica towed from The Dragon in 2008. vip09 helped Azzy get to The Dragon in 2009. vip09 helped KM replace his 5-year-old clutch.
    Mobile, AL
    Here is the part number: 11291-88380
    It is available on the Lithia website.
    Best GT-S STOCK times: 1/4: 14.788 @ 94.98mph 1/8: 9.640 @ 75.87mph
    Best Alltrac times: 1/4: 12.2 @ 115mph 1/8th: 7.9 @ 91mph
    Originally Posted by forgies
    look vip is the ultimate celica driver... He needs a section of celicatech devoted to him!
    Martinez, CA
    Thanks, I ordered it from their web site.
    ST165
    I also need these for a 91 GT4. Are they the same?
    Mobile, AL
    Yep, same part number.
    Martinez, CA
    It was like $12 shipped, it will be way worth it.
    ST165
    The sticker is actually available, but the fact that a part number is still on the database does not mean that the part still exists. It is definitely worth checking on old or uncommon parts.
    Martinez, CA
    Revived it yesterday looks perfect, thanks Aaron
    Sent from my HTC Sensation Z710e using Tapatalk
    ST165
    You're welcome. Thank you!
