Results 1 to 13 of 13
    Martinez, CA
    Default Aftermarket u-joint/spider joint
    Having a hard time finding non oem ujoints for my st165 drive shaft
    Sent from my HTC Sensation 4G using Tapatalk
    ST165
    Martinez, CA
    ok so according to toyota the part number for the spider kit/u-joint is 04371-60100 and according to toyotapartscheap.com the same u-joint fits many toyotas. So an aftermarket u-joint from one of the other toyotas should work for the ST165.
    Mechanical Catalog
    Item Number MSRP Core Price Price
    0437160100 $69.78 $0.00 $55.82
    Front drive axle - Drive axles - Propeller shaft - Universal joints
    Universal joints, 4runner, 2wd 2010
    Add to Cart Contact Us
    Universals & rear axle - Drive shafts - Propeller shaft - Universal joints
    Universal joints, celica 1989 - 1993
    Universals & rear axle - Rear axle - Propeller shaft - Universal joints
    Universal joints, supra - independent type 1984 - 1992
    Universal joints, pick-up, 2wd 1991 - 1994
    Universal joints, 4-runner, 2wd 1991 - 1994
    Universal joints, previa, 2wd 1991 - 1994
    Universal joints, pick-up, 4-runner, 4 cylinder, 2wd, manual trans, 5-speed 1984 - 1990
    Universal joints, pick-up, 4-runner, 4 cylinder, 2wd, auto trans 1984 - 1990
    Universal joints, pick-up, 2wd 1995
    Universal joints, 4-runner, 2wd 1995 - 2002
    Universal joints, 4-runner, 4wd, 2wd 2003 - 2009
    Universal joints, tacoma, 2wd 1995 - 2000
    Universal joints, tacoma, 2wd, 2.4l, toyota 2001 - 2004
    Universal joints, tacoma, 2wd, 3.4l, manual trans 2001 - 2004
    Universal joints, previa, 2wd 1995
    Universal joints, previa, 2wd, toyota 1996 - 1997
    http://www.trademotion.com/partlocat...&siteid=214001
    Narrow Your Results
    search
    attribute
    You Selected:
    Drive Type [Rear Wheel Drive]
    clear vehicle attributes
    brand
    Master Pro U-Joint (4)
    Precision (6)
    price
    under $10.00 (3)
    $10.00 - $29.99 (7)
    availability
    In Store Now (7)
    Online Now (10)
    On most orders
    On most orders
    of $75 or more!
    Click for Details
    1 - 10 of 10 results
    View:
    Sort by:
    Most Popular
    Price Low to High
    Price High to Low
    Brand
    Master Pro U-Joint - Universal Joint
    $8.99 Each
    Add to Printable List
    Online: Available
    Store: Available
    2 Year Limited Warranty
    Multiple Applications
    Center
    - Rear Wheel Drive
    - Standard Kit
    - 4 Outer Snap Rings
    - 1.063 Inch Bearing O.D.
    - Quantity Per Vehicle: 1
    Front
    - Rear Wheel Drive
    - Standard Kit
    Rear
    - Rear Wheel Drive
    - Standard Kit
    Part # : 369 | Line: MPJ
    $9.99 Each
    Online: Available
    Store: Available
    Front
    - Rear Wheel Drive
    - Optional Kit
    - Flushed Zerk
    Rear
    - Rear Wheel Drive
    - Optional Kit
    - Flushed Zerk
    Center
    - Rear Wheel Drive
    - Optional Kit
    - Flushed Zerk
    Part # : 379 | Line: MPJ
    $11.99 Each
    Online: Available
    Store: Available
    Center
    - Rear Wheel Drive
    - Optional Kit
    - Zerk In Bearing Cap
    Front
    - Rear Wheel Drive
    - Optional Kit
    Rear
    - Rear Wheel Drive
    - Optional Kit
    Part # : 380 | Line: MPJ
    $8.99 Each
    Online: Available
    Store: Available
    Rear
    - Rear Wheel Drive
    - 4 Inner Snap Rings
    - 1.142 Inch Bearing O.D.
    Center
    - Rear Wheel Drive
    Front
    - Front Shaft
    - 4 Wheel Drive
    Front
    - Rear Shaft
    - 4 Wheel Drive
    Front
    - Rear Wheel Drive
    Rear
    - Front Shaft
    - 4 Wheel Drive
    Rear
    - 4 Wheel Drive
    Part # : 387 | Line: MPJ
    Precision - U Joint - Non-Greaseable Super-Strength
    $17.99 Each
    Online: Available
    Call Store: Usually Avail. 24 Hrs
    Find store with item
    Limited Lifetime Warranty
    Rear Wheel Drive
    Regular Cab
    With Outside Lock Rings
    A1- At Transmission
    A2- At Rear Axle
    Part # : 269 | Line: PRE
    Precision - U Joint - Greaseable Super-Strength
    $18.99 Each
    Online: Available
    Store: Available
    Rear Wheel Drive
    Regular Cab
    A1- At Transmission
    A2- At Rear Axle
    Part # : 280 | Line: PRE
    $23.99 Each
    Online: Available
    Rear Wheel Drive
    - Extra Cab
    - B1- At Transmission
    - B2- At Center Bearing
    - B3- At Rear Axle
    Rear Wheel Drive
    - Regular Cab
    - With Inside Lock Rings
    - A1- At Transmission
    - A2- At Rear Axle
    Part # : 285 | Line: PRE
    $21.99 Each
    Online: Available
    Rear Wheel Drive
    - Extra Cab
    - B3- At Rear Axle
    Rear Wheel Drive
    - Regular Cab
    - A2- At Rear Axle
    Part # : 287 | Line: PRE
    Precision - U Joint - Premium
    $14.99 Each
    Online: Available
    Store: Available
    Rear Wheel Drive
    Regular Cab
    A1- At Transmission
    A2- At Rear Axle
    http://www.oreillyauto.com/site/c/se...niversal+joint
    ST165
    Martinez, CA
    so now the question is greasable or non-greasable?
    ST165
    I'd go greasable, and stay away from Precision brand if you can.
    '92 ST185 All trac
    '92 AE95 wagon x2
    '72 TE27
    Martinez, CA
    stay away from precision, why? I have heard only good things about them.
    ST165
    I've owned almost 50 vehicles (I'm in my 30's) and about half were trucks. The ones that I used precision brand were the only ones I had trouble with, ie. brinelling, premature failure, shoddy materials (rolling elements), different measurements across the pins, etc...just crap IMO.
    '92 ST185 All trac
    '92 AE95 wagon x2
    '72 TE27
    Martinez, CA
    So what brand should I look into? I have heard good things about Spicer.
    ST165
    Martinez, CA
    so what do you guys think about spicer u-joints? from what i can find they are one of the best.
    looks like the spicer 5-1510x will work for the 88 alltrac.
    ST165
    Spicer makes the OE driveshaft for the gen 2 tundra. The same tundra has a driveshaft recall.
    Martinez, CA
    Well, does anyone have a good brand to go with? Or should I bite the bullet and get some Toyota ones?
    ST165
    Spicer is a very good brand.
    '92 ST185 All trac
    '92 AE95 wagon x2
    '72 TE27
    Nov 2009
    Cary, NC
    In my "distant" past experience with American cars - Spicer was always a common and quality brand for driveline components.
    Stil - these days - you never know what you are getting.... I would recommend NAPA if you don't want to use the dealer stuff - as the NAPA Altrom line parts in many cases are essentially OEM boxed components which are "re-branded" by Toyota and other car manufacturers.
    I build drivelines at work on a regular basis, just reporting based on my hands-on experience.
    '92 ST185 All trac
    '92 AE95 wagon x2
    '72 TE27
