    Default Part numbers & compatibality between generations
    I'm having trouble compiling a full cross-generation part number list between the st162 (87 GTS) and a 90-93 GT/GTS for suspension parts. I need some for my st162 (well for both of them actually) and see that most of the 162 parts are out of stock/discontinued/eternal backorder at local dealerships but the st182's are not.
    I'm looking for the following part numbers/availability for the st162/st182 (GT/GTS trims).
    Lower Ball Joints
    Front Sway Bar Links
    Rear Sway Bar Links
    Inner Tie Rod (LT)
    Inner Tie Rod (RT)
    Outer Tie Rod (LT)
    Outer Tie Rod (RT)
    FR wheel bearing
    FL wheel bearing
    RR wheel bearing
    RL wheel bearing
    Thanks!
    You will need to use an EPC (or a site like toyodiy) if you want to compare part numbers across platforms. You should know beforehand that it can be very time consuming and there's very little point:
    If a part number isn't available, it isn't available, regardless of how many other platforms it applies to.
    If a part from one platform fits another platform, they will typically carry the same part number.
    If two different part numbers that do not supersede can be used in place of each other, you'd have to discover it on the car, as Toyota does not list dimensions or technical data.
    All of the parts you asked about are available. You're certainly welcome to order from our website if someone else is not performing for you!
    ST162 - - - - - - - - ST18# FWD - - - - - DESCRIPTION
    43330-29185 - - - - 43330-29326 - - - - Front Lower Ball Joint*
    48820-20010 - - - - 48820-20010 - - - - Front Sway Bar Link
    48830-20010 - - - - 48830-20010 - - - - Rear Sway Bar Link
    45503-39025 - - - - 45503-29245 - - - - Front Inner Tie Rod
    45046-19175 - - - - 45046-19175 - - - - Front Outer Tie Rod
    90369-38003-77 - - 90369-38003-77 - - front wheel bearing**
    90369-30044-77 - - 90369-30044-77 - - rear wheel bearing***
    * Update requires castle nut 90080-17214 and cotter pin 95381-03025 or equivalent
    ** ST162 requires seal kit 04422-20010; ST18# FWD requires seal kit 04422-20110 for non-ABS cars, 04422-20080 for ABS cars (one each per wheel)
    *** ST162 and ST18# FWD require seal 90311-42018 and o-ring 90301-63006 (one each per wheel)
    Wooot!
    Thanks
