    Default Part numbers por favor
    -2jzgte (OBD1 if it matters) t-belt tensioner. (don't need idler)
    -coil pack connectors, my wires are fine but some of the connectors have cracked.
    The tensioner is easy. That part number is 13540-46030. For the connector housings, Toyota doesn't call them out by application in most cases, so you're going to have to identify them visually. There's a selection of catalogs here to look through:
    http://www.ih8mud.com/tech/WireHarnessRepairParts.php
    Ok, thanks, order placed for the tensioner!
