Results 1 to 6 of 6
    Jul 2006
    monroeville alabama
    Default How to: Oil cooler on a 7th gen
    How to: Oil cooler on a 7th gen.
    You will need:
    Oil union (from japan 90402-28004)
    Oil cooler retaining bolt (modified camry one) You have to run a die down the threads all the way to the oil cooler and cut off the excess.
    Oil Cooler /w new o rings (mid 90's camry)
    4' of 1/2" heater hose
    4 clamps
    Some oil and coolant
    Special tools:
    12mm Allen socket
    Large socket for the oil cooler bolt (30mm i think)
    3/4 -16 die
    Metal file
    Dremel
    You can do this without draining the oil but you will lose a couple onces and some coolant.
    1. Remove the oil filter.
    2. Remove the 12mm allen bolt union the oil filter screwed to.
    3. Install the new oil union.
    4. Remove the intake manifold. (this requires a lot of unbolting)
    5. Install 2' of hose on either side of the oil cooler with clamps
    6. Install oil cooler loosely with modified bolt.
    7. Remove the clamps holding the rubber covers on the coolant pipes.
    8. Meassure and cut one hose at a time and install them on the pipes where the covers were with clamps. It doesnt matter which one goes where. just dont kink the coolant lines. I ran mine up by the AC compessor.
    9. Tighten the oil cooler down with the hoses sticking out as far left as they can go.
    10. Install intake manifold and oil filter.
    11. Top off oil and bleed coolant.
    Done
    Very nice. Im gonna sticky this.
    Jul 2006
    monroeville alabama
    Stay outta my forum bish.
    Golden, CO; Azz's Pants
    Sticky or not it has to be said. Huh huh, nut union.
    Very nice work Bugs, I can see this being feasible on other engines as well.
    The Coupe:
    The Hatch:
    CelicaTech Supporter bzdweezy is on a distinguished road bzdweezy's Avatar
    bzdweezy has donated to the forums!
    Oct 2007
    Houston/Corpus Christi(College), Tx
    Nice write up i always wanted to add one.
    So how much extra oil do you add with the cooler installed?
    1991 Celica Gt 313,000 miles
    2005 Celica Gt -
    7/9/10- Stage 3 clutch and flywheel installed
    8/24/10- Turbo kit and dyno complete
    Jul 2006
    monroeville alabama
    Im guessing the first fill up maybe a couple ounces, its a tiny cooler. After that it wont take any more from a normal oil change because the cooler will retain some oil in it i believe.
