    Default 1st gen and 2nd gen 3sgte clutch same?
    I bought a 88 alltrac and wanting to know if the 2nd gen 3sgte clutchs 90-93 would work because they are easier and cheaper to find. Or would a st205 clutch and flywheel stock. Thanks
    ST-184.. 1990 Toyota Celica GT-S(Sold)
    ST-165.. 1988 Toyota Celica Alltrac(Project/weekender)
    ............ 1995 Acura Integra LS(Daily Driver)
    Martinez, CA
    no, they are not the same. you might be able to use one if you change the flywheel to a newer one, but the newer clutch will not bolt to the st165 flywheel.
    ST165
    Quote Originally Posted by jaydog82 View Post
    So how about if i get the st205 flywheel and clutch? The reason im asking is someone is selling one locally and thought i might grab it.
    The crank is a different bolt pattern on the 1g
    Darn so it cant work ? hoping it could becuase it was a real cheap buy
