Results 1 to 18 of 18
    Default pulstar pulse plugs
    ok, so i was just reading one of my ricer mags(i like it for the articles i swear)and i saw this ad for something called the pulstar pulse plug....it claimed that it adds 11 hp over regular platinum plugs... what do you guys think about this? has anybody used them? im not gonna go get a set but i was just wondering if anybody on here knows anything about them.
    -2006 Nissan Sentra SE-R
    [Ryan] 2:40 pm: I saw that one but I want to make one my own... lol. And a pic of andy on my leg would make all the girls jealous, good idea
    [Murgatroy] 2:41 pm: Yeah, but sitting crosslegged to masturbate would just be kinda creepy.
    Shadow's Minion army - member #1
    expensive... haven't met anyone who's used them.
    RICE WHITE ALLTRAC
    That claim is true, by the way.
    If you have a VQ35.
    No clue what it would do with a 5sfe or something similar.
    If it added 11hp to our cars, then it would be worth the money. But i HIGHLY doubt it'll add more than 3-4, if anything. And that's not worth the money, unfortunately.
    Ultimo Miembro Fantástico Gigantesco Slider will become famous soon enough Slider will become famous soon enough Slider's Avatar
    Chicago, IL
    Interesting but I'll stick to my cheap NGK V-Power coppers. Like ciento said the gain will be minimal, or non-existent.
    '90 Celica GT
    '95 Miata
    You are aware that copper plugs give power gains over platinum plugs right?
    let's eat lburner has a spectacular aura about lburner has a spectacular aura about lburner's Avatar
    lburner has donated to the forums!
    Jul 2005
    newark,de -- new orleans,la
    it did help my (mpg) a lil
    ^you used them?
    I fail to see how paying $15 a plug for spark plugs is even considered an option.
    I don't spend $15 a year in spark plugs, much less a piece.
    i wasnt thinking about it, i just saw the ad n was just curios
    Chicago, IL
    Quote Originally Posted by Murgatroy
    just spend the money elsewhere, install a couple tornados in the intake
    '90 Celica GT
    '95 Miata
    my subaru plugs are 13 dollars a pop
    Chicago, IL
    Quote Originally Posted by 85gtsblackman
    Those are iridium or platinum though from the factory right?
    '90 Celica GT
    '95 Miata
    irid's
    yeah they are factory plugs i got from napa, not the dealer, napa, yes exact same factory ngk plugs
    Chicago, IL
    Just curious, is it hard to replace the plugs on those motors? My friend has a 2.0 WRX and he doesn't want to do them, he said the people on the boards said it was a PITA. It made me that he replaced the entire turbo back exhaust + up pipe, and dropped the tranny and changed the clutch but he's afraid to tackle some spark plugs.
    '90 Celica GT
    '95 Miata
    sorry for dredging up a 'dead thread...'
    i've re-visited the idea of the Pulstar plugs.
    http://www.sparkplugs.com/files/Prin...%20Feature.pdf
    on the 'sparkplugs.com' website, it lists the BE1 plug (for all 3s, and most likely 5s, applications) for $12.95 each. i'm curious if 'sparkplugs.com' receieved a bit of a kickback for doing the article/pdf, or if was a true and honest test.
    it is nice that they show only minor (realistic) improvements on the b18, and not WHOPPING HP increases across the board.
    Independent AMSOil Dealer
    Senior Member jaydog82 is on a distinguished road
    Martinez, CA
    i read an article a while back that said the pulse plugs are not any better then the cheaper premium plugs, also the pulse plugs do have different levels to their plugs( copper-platinum-iridium). i thought about trying the iridium ones, i can get them for $15 for a 2 pack, but i have not decided yet.
    http://chris.pirillo.com/spark-plugs-vs-pulse-plugs/
    http://www.carbibles.com/productreviews_pulstar.html
    ST165
    JDM engine and new turbo. SPEC stage 2 clutch,walbro 255lph fuel pump, AEM dry flow filter and custom 3" straight intake, 3" ausie DP, upgraded HE and heat wrapped ST165 WTA IC, 8mm magnacore wires, speedsorce solid motor mounts, ASI Aluminum RAD, 2micron second oil filter kit, prosport EGT-BOOST-WB O2 gauges, all new: seals/gaskets/belts/hoses/ Water Pump/ Timing belt kit, Rebuilt half shafts, new drive shaft u-joints, new control bushings, cleaned and balanced injectors,
    A friend of mine bought those for his h22 civic (195 hp) and riding in it, you can tell it idled better and got better mpg but didnt feel like any hp gains, unless you use them in a like a v8 or something i dunno if you will see gains especially with a 5sfe
    Bull fucking shit. Spark plugs don't make power. An msd box doesn't make power. A hot coil doesn't make power.
    If you are running nitrous or lots of boost or very high compression then I can see getting an msd. But these plugs are most likely a sham. Something like nology wires I'm assuming. Unless you are really modified just get the plugs from the dealer.
