Page 2 of 2 FirstFirst 1 2
Results 26 to 34 of 34
  1. #26
    Jun 2009
    Fullerton, California
    Can you please take a picture of the locations of the clutch start, clutch cancel switch and reverse light switch? I had a hard time trying to find them today at PaP.
    Thanks again man. I'm psyched that I'm finally getting around to this.
    - Dustin J.
    1991 Toyota Celica GT
  2. #27
    The clutch safety switch is located at the top of the clutch pedal on a bracket. Much like the brake like switch. The reverse light switch is right on top of the transmission. It has a 2 wire harness.
    Reverse light switch
  3. #28
    Jun 2009
    Quote Originally Posted by Hookecho View Post
    Thanks! One more question, do you know if 6th gen (S54) or 4th gen shift cables will fit on a 5th gen? I'm having a really difficult time trying to find a set. If I can get them from a 4th/6th gen as well I can broaden my search a little.
    - Dustin J.
  4. #29
    They fit. I have a set from a 4th gen on mine.
  5. #30
    And a 4th Gen MC and line will fit too. The reservoir just sits a little under the wiper motor.
    Jun 2009
    I struck gold right after posting this. I messaged someone on eBay who was selling a shift assembly and asked if they had the cables - they did!
    ...cost me $125 after shipping though. At least it's better than what my local dealership wanted for them ($600 for the pair!).
    - Dustin J.
  7. #32
    Jun 2009
    If I have my cruise control vacuum lines plugged/never use it then I shouldn't need the start/cancel switch right? Or will it prevent something else from working correctly?
    - Dustin J.
  8. #33
    Jun 2009
    How do I remove the hood lever/latch? I'm almost done with the swap, working on clutch pedal/brake. I have the plastic and metal plates disconnected but the trunk cable is hanging them up.
    EDIT: I realized I said trunk, oops...
    - Dustin J.
  9. #34
    Jun 2009
    Trans bell housing bolts x3(you can use the ones from the auto trans)
    So, do we or do we not need bellhousing bolts? I'm looking at this guide here:http://www.toyotacelicaonline.com/atomconv1.htm
    And it says they are different.
    - Dustin J.
