    Default alltracst185's project 90 all-trac
    Rather than go all out and post pics of my build progress from start to finish, i'll post how it sits as of 1/1/11. If you want you can check out my build from start till presant here http://www.alltrac.net/phpBB2/viewto...p?f=44&t=22608.
    and here is a sumwhat of an accuate parts list
    ENGINE
    3sgte bored 20 over
    CP 9:0/1 pistons
    Eagle H beam rods & ARP bolts
    polished and balenced 3sgte crank
    ACL race bearing (rods and main)
    HKS GT3040 turbo (powdercaoted Purple metalic)
    3" SS V-band conversion
    SS ramhorn ex manifold
    Tial 38mm ex wastegate
    custom SS down pipe
    Finadanza flywheel
    6 puck clutch
    new OEM bottom end gasket kit
    Powdercoated Purple metalic shaved OEM valve cover
    HEAD
    mild port and polish
    Engle valve springs
    new OEM valve seals
    HKS 272 cams
    HKS ajustable cams
    HKS kevlar timing belt
    Cometic head gasket
    RMR intake maini
    KO Racing phenolic spacer(TVIS deleted)
    BBK 70mm throttle body
    new OEM top end gasket kit
    new OEM water pump
    ATS high volume oil pump
    new OEM belt tensioner
    new OEM tensioner pulleys
    ARP head studs
    ARP flywheel bolts
    FUEL
    Speed-Source top feed fuel rail
    Presision 880 top feed injectors
    Aeromotive FPR
    Walboro 255 in tank fuel pump
    cusom SS fuel lines
    new OEM injector spacers & seals
    ELECTRONICS
    AEM EMS
    HKS turbo timer
    Inovative LC-1 wideband O2
    Eclipse 7" double din DVD/CD
    Rockford Fosgate 500 RMS amp
    custom 12" sub enclosure (made by me) with MA Audio 12" XL 700 RMS dual coil sub
    INTERIOR
    Sparco racing seats
    Sparco seat mounts (side mount)
    KYO seat brackets
    Sparco harnesses
    Sparco Racer 2 steering wheel
    NRG quick release mount
    WHEELS & TIRES
    STREET
    Axis Decades 18x8.5 front and 18x9.5 rear
    Continetal contacts 225/35/18 front and 235/30/18 rear
    DRAG
    Rota Revs 17x8
    Bridgestone Potenzas 225/45/17
    1" spacer in the rear
    SUSPENSION
    K-Sport coilovers
    MISC
    CS/RC front bumper
    custom 3" FMIC and piping
    custom 4" intake
    Samco radiator hoses
    Cusco oil catch cam
    custom aluminum overflow (made by me)
    Speed-Source poly motor and tranny mounts
    Speed-Source SS clutch line
    2's R us valve cover bolts Hallman maual boost controler
    MSD blaster coil
    MSD plug wires
    NGK one step colder plugs
    Goodridge SS brake lines
    ABS delete
    FUTURE PLANS
    Willwood BBK
    St205 rear brakes
    St205 rear LSD
    Cusco under brace
    Cusco rear strut brace
    Cusco front strut brace
    custom fabbed rollcage
    respray Toyota super Red
    OEM st185 floor matts
    CS/RC hood
    CCW Classics custom offset wheels
    The board requires you to be registered and logged in to view this forum.
    This makes it against our forum policy to link to.
    Your build looks fantastic, though.
    Quote Originally Posted by KM View Post
    Oh, sorry!
    Well for the people that want to see before and afters of my build just register to alltrac.net to see, and thanks KM
    Looks really good! What's your timeline to startup? Did you build the engine?
    1994 ST205 WRC
    i'm hoping within a month or so and yes i did build the engine
    Ordered the last of my parts lastnight...should be up and running soon!
